Old 01-29-2007, 03:20 PM
96transamguy88's Avatar
96transamguy88 96transamguy88 is offline
o2 sensors????
hey guys, ive got my new pacesetter lt's on and i was wondering the best way to install my old o2 sensors back in... the instructions say that i sould splice the o2 wires and add more wire... is that the best way to do this??? thanks kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
slp fan control switch
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Daily Driver-86 4wd danger ranger
Old 01-29-2007, 04:19 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: o2 sensors????
you have three other options other than splicing. They make extensions so you dont have to cut any wires. Or you could find someone with lt1 programming software and have the two rear o2 sensors edited out....i think the lt1 motors had 4 didnt they??? Or you could get o2 simulators to replace your o2 sensors.
take your pick
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-29-2007, 09:15 PM
Re: o2 sensors????
ya they had 4 all together...... cool thanks for the info... im really not sure way would be the best but now i know what im going to look for.
thanks kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 02-11-2007, 12:27 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: o2 sensors????
removing oxygen sensors on a fuel injection setup is just a bad idea. it creates drivability problems like, poor gas mileage, a constant rich air/fuel ratio, and decreased engine effieciency. just splice the wires and make them longer: a very simple process. use a similar guage/size wire, and make sure it is tied up and routed away from touching the headers.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 02-11-2007, 04:27 PM
goldz28's Avatar
goldz28 goldz28 is offline
Re: o2 sensors????
If you remove the pre cat o2 sensors you will have problems. The rear o2 sensors don't do anything but tell the computer that the cats are working properly. I have LT headers and do not have drivability problems. Your check engine light will be on and that is a pain in the butt but other than that no problems. I am not sure if OBD1's even check the rear o2's might want to check that out also.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 02-11-2007, 04:41 PM
Re: o2 sensors????
well i was just going to buy some extensions for the 2 o2 sensors that are before the cats from http://www.lmperformance.com/4116/2.html , and i can get 12 to 34 inches. i think that would be a good way to go. let me know what you guys think.
thanks kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 02-11-2007, 05:48 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: o2 sensors????
Good.
Never splice an O2 wire. Incorrect readings will be had.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 02-11-2007, 06:13 PM
Re: o2 sensors????
ok. i stand corrected. i have little experience with ODBII system. I was not aware there were rear O2 sensors on 4th gens.
Old 02-11-2007, 10:33 PM
poormillionaire2 poormillionaire2 is offline
Re: o2 sensors????
Ha, I spliced my driver's side O2 wires and bought a new O2 sensor and a pre-made extension for the passenger side. I bought a new O2 because the other one was stuck in the manifold.
But I drove around for a few days with only the driver's side installed because I was waiting on my other parts. Never had an SES or codes either.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 02-12-2007, 08:22 AM
Re: o2 sensors????
Originally Posted by Mr. Luos
Good.
cool, thats what i was thinking. another question though, are the back two o2 sensors just left out with headers and an off road y-pipe?
thanks guys
kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 02-12-2007, 08:27 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: o2 sensors????
the pre-cat rear sensor shoudl still be there to maintain your AF trms... long term i believe.
Post cat is useless and can be deleted (tuned out)... its only purpose in life is to pop up codes when you remove your cat
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
