| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
No heat in bro's Ford bronco?
I know a few of you guys on here are mechanics and a few others have domestics. So I figured I ask my fellow dsmer's for help. My bro's truck is blowing air but it doesnt seem to get hot. This has just started happening all of a sudden. Any idea's of what the problem could be?
Thanks guys.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels --the DD-->99 ACURA 3.2 TL --Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods |
Re: No heat in bro's Ford bronco?
Sounds like it could be a heater core, or something wrong with that cable thats connected to the valve, when you switch from hot to cool. Is there any coolant leaking in the passenger side floor board? I think thats where the heater core is
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
I'll have to check for a leak when he gets home with the truck. Thanks for the help.
Does he let the car warm up before he turns on the heater? Heaters pull warm air from the coolant to heat your vehicle, so if the coolant is still cold then that's all it would be blowing. I usually keep my heater off until the needle gets at least on the gauge before I turn my heater on.
![]() I'd start simple and cheap... if the car has started overheating, probably the thermostat... might wanna check and make sure the car has enough coolant... if it gets air in there, it won't flow the coolant properly, can overheat the car and keep it from blowing hot air (no coolant passing through the heater core)... but als look for that leak... and make sure all the coolant hoses look fine (not swollen, leaking, busted, etc)... check those then let us know
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
yup low coolant can cause no heat, plugged heater core. Heater core does not have to leak to be bad. Sometimes you can open troubles in other places doing this IMO but you can run radiator flush to see if that breaks the junk up if it is plugged.
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Thanks for all the responses. Im going to look at the truck during the week and def pick up some radiator flush.
We flushed it out today. He said it feels hotter so far so i guess tomorrow will be the true test.
He said its still not as hot as it should be. A week ago he said it felt way better. He warms it for like a half hour too. What to try next?
Does the engine fully heat up to normal operating temp? It won't do that if he turns on the heat and is constantly pulling heat from the motor before it even warms up.
thermostat could be stuck open
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
![]() I was thinking of it being stuck closed (which is what I've seen here lately), but it could possibly be stuck open. I'd start there, thats a cheap and simple fix if that's what it is...
easiest way to check that is let the truck warm up and grab the upper rad hose, if its hot your golden if its cool/warm you have a problem.
If the thermostat was stuck open and it was somewhat cold out, the vehicle wouldn't heat up at all, you'd be lucky to even get the gauge to move. That's why I asked if the gauge moved to normal operating temps.
