Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-29-2007, 07:35 AM
jonnik jonnik is offline
Flasher relay
Does anyone know where the turn signal flasher relay is located on a 2004 Clasic?
Old 01-29-2007, 09:33 AM
Malibu_Newbie Malibu_Newbie is offline
Re: Flasher relay
Should be listed in here section 5.
opps forgot the link:
http://www.analogstereo.com/pdf/om/2k04malibu.pdf
Old 01-29-2007, 12:06 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Flasher relay
The flasher is part of the hazard light switch, and controls both the turnsignal and emergency flashers.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-29-2007, 03:33 PM
CRASH IT CRASH IT is offline
Banned
Re: Flasher relay
wasn't there a recall on that part?
Old 02-01-2007, 02:37 PM
DRAGONRACER76 DRAGONRACER76 is offline
Re: Flasher relay
yes there was. don't take it out. let the dealership change it out. it won't cost you a dime.
Old 02-05-2007, 01:49 PM
Talking Re: Flasher relay
Thanks, guys, for the info on the recall. Will hit the dealership the first chance I get.
Old 02-06-2007, 10:04 AM
Re: Flasher relay
Just an update-that recall ended with 2001 model year.
Old 02-07-2007, 09:37 PM
Brandish's Avatar
Brandish Brandish is offline
Re: Flasher relay
If your flasher relay is going bezerk, there is a way to fix it without spending $300+ at the stealership...
Old 02-09-2007, 11:40 AM
Re: Flasher relay
Thanks for the input, guys! Did it myself, 30 minutes and $35 took care of it.
Old 02-10-2007, 11:33 AM
fisherdm fisherdm is offline
Re: Flasher relay
What was the $35 quick fix? Turn signal on my 97 Malibu has been intermittently working for the past month. Changed the bulbs and fuse w/o benefit. I looked in my Chiltons manual and can't find the location of the relay for the turn signals.
Old 02-11-2007, 10:30 AM
Re: Flasher relay
On my car, the flasher relay is integrated in the hazard switch.
Old 02-11-2007, 05:54 PM
Re: Flasher relay
Bear with me, I am not very car literate. Where is the hazard switch? I suspect you don't mean the one on the dash (or do you)? Any details you can give about the $35/30 minute fix is appreciated.
Old 02-12-2007, 07:05 AM
Re: Flasher relay
Yes, the one in the dash that turns on the hazard flashers. I believe that your car is very similar to mine. There are 2 screws in the bezel above the instrument cluster that must be removed. Then CAREFULLY pry off the bezel-it's held on by several clips. The switch is removed/installed from the rear of the bezel. I hope this helps, I got my new switch from a dealer. Ask the parts guy if you can see an exploded view of the dash to get an idea of how the switch is removed. Good luck!
Old 02-12-2007, 06:07 PM
Re: Flasher relay
Jonnik, Your post about the flasher relay being part of the hazard switch promted me to test my hazards when the flashers stopped working. My hazards still work when the flashers did not. Do you recall if your hazards still functioned when your flashers did not?
Old 02-13-2007, 07:19 AM
Re: Flasher relay
When my turn indicators would quit, I could turn on the hazard flashers and they would work, and the turn indicators would also work for a while. I think the relay was at the point where the 2 turn indicator bulbs would not draw enough current to activate the relay, but the 4 hazard bulbs would. My turn indicators have been working without fail for a week now, when before they would fail 1 or 2 times a day.
