Old 01-29-2007, 02:22 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Axle Removal
Ok, I can't exactly get to my helms manual right now and it'll be awhile before I can. How do you remove the axle from the steering knuckle and does anyone make an aftermarket steering knuckle.
AF COMMUNITY GUIDELINES
Old 01-29-2007, 04:41 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: Axle Removal
im pretty sure theres just a giant nut that holds the axle to the steering knuckle.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 01-29-2007, 05:52 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Axle Removal
Yeah. The nut might give you some shit. If it does, heat it up with a torch and then try again. To get the axle out of the hub you'll need to seperate the lower ball joint and remove the bolt that connects the bottom of the shock to the lower control arm.
As for aftermarket knuckels, none that I'm aware of.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
