Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-29-2007, 12:22 AM
mpfilms mpfilms is offline
noise from the right front section
00 CVPI I'm trying to figure out what would cause this creaking sound when i turn extreme left and right. it just started doing it. it sounds like old metal rubbing on a boat or a old door in a scary movie creaks. it's coming from the front right side. thanks
Old 01-29-2007, 06:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: noise from the right front section
Probably tie rod ends or ball joints. Jack vehicle up, remove tie rod ends and turn the wheel to see if the noise is still there. If the noise is gone, tie rods are bad, if noise is still there, ball joints are the problem.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-01-2007, 11:45 PM
gskellogg gskellogg is offline
All of the crown vics police interceptors (98 and up)that I have driven make that noise, especially when doing a quick U-Turn.
Old 02-03-2007, 02:27 PM
sheebeehuh sheebeehuh is offline
Tie rods are easy enough to check and replace. See here...
http://www.autoclinix.com/Mercury/TieRods.html
My '97 had a "pop" noise when I turned too sharp. In my case it was the upper ball joints. You might check the sway bar end links as well.
Old 02-03-2007, 09:37 PM
1996Chreokee 1996Chreokee is offline
sounds like control arm bushings ... very creeky and i have seen alot of them replaced on the old p71's
Old 02-05-2007, 07:53 PM
it was the ball joints. thanks
Old 02-24-2007, 09:05 PM
Cool Re: noise from the right front section
It's probably a little late now to help out mpfilms but this link...
http://www.autoclinix.com/Mercury/BallJoints.html
has good info on replacing the upper ball joints yourself. I replaced mine and my front-end "clunkage" went away.
