Old 01-28-2007, 11:31 PM
scrowler scrowler is offline
car runs badly with no throttle response
1987 ford laser ghia, 1.6L EFI engine, 230,000 km
hi,
recently my car was not running at all, i found the fault to be the fuel pump, which i replaced, and now it starts and idles.
as soon as i put the throttle in, the rev's go down, and when i let it out it jumps up a thousand or so then back to normal, running pretty badly (spluttering, backfiring etc).
i can give it gas and it will slowly increase the revs to about 3000 spluttering and backfiring, then after that it seems to go up a bit smoother to the higher revs.
if i clamp the fuel return hose a bit then it's a bit smoother when i give it more throttle, but that puts strain on the fuel pump and i don't want to do this at all.
the exhaust has a little white/grey smoke coming out (not alot) and i saw a tiny plume of smoke coming from what looked like the exhaust manifold.
can you help me? thanks,
robbie
Old 01-29-2007, 10:43 PM
gouldie1903 gouldie1903 is offline
Re: car runs badly with no throttle response
my guess is fuel fliter
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 01-29-2007, 11:59 PM
GreyGoose006 GreyGoose006 is offline
no, i dont think so.
that would have to be one seriously screwed up fuel filter, although it does seem like a possibility.
even so, it doesnt explain all the other symptoms.
start checking sensors i guess...
Old 01-30-2007, 01:10 AM
yea when fuel filter clogged i had similar symtoms with out the smoke, but the metal line before the filter was rusting from the inside. i took it off and turned it upside down and hade a nice little pile of rust
Old 01-30-2007, 02:27 AM
fuel filter hmm wouldn't have guessed that was the problem... i'm going to check the computer for error codes tomorrow
Old 01-30-2007, 04:11 PM
what happens if it is idling and you quickly floor the throttle (in neutral)
if it were the fuel filter and it were clogged that badly, it would probably stall.
my guess is something else is going on, but i could be wrong.
the good news is that fuel filters are pretty easy to change.
Old 01-30-2007, 04:23 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Clean the MAF.
had similar problems with the Golf, got the MAF all cleaned up and it worked perfectly.
Seatbelts Saved My Life
Old 02-04-2007, 07:23 PM
the fuel filter is pretty new and the air filter is brand new... are they really worth replacing?
Old 02-04-2007, 09:53 PM
like i said, its probably not the fuel filter.
it sounds like a sensor issue.
maybe some kind of throttle position sensor or airflow sensor.
