Old 01-28-2007, 08:50 PM
Kevster324 Kevster324 is offline
Airbag light on
It flashes at startup, then stays on. Someone suggested checking connections. Where are those connections???
Old 01-28-2007, 10:11 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Airbag light on
Messing with the airbag system is risky. You may not find too much help. Static electricity can set off a bag..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 02-10-2007, 10:33 PM
1996LTOwner 1996LTOwner is offline
Re: Airbag light on
Try tilting your steering wheel in different positions and see if the light flickers or goes out. My wife started driving my blazer and would lower the steering wheel every time she got in and raise it to get out. Eventually, she broke the air bag wire about a 1/4" away from the air bag. Luckily, I was able to strip the wire with a very sharp knife, slide over a piece of shrink tubing, solder the ends and seal the connection with the shrink wrap. If it blew, I was forward of and below the steering wheel anyway. Unless you like taking chances, I'd suggest, as stated by d3, have it replaced for you.
Old 02-12-2007, 04:26 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Airbag light on
Check the fuse first and if you go into the steering wheel pull the fuse or you will probably set it off!
