Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-28-2007, 09:42 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
1983 regal v6 to v8 swap questions
a friend of a friend has an 83 regal with a carbed v6/auto tranny and wants to swap in a carbed 305/700r4 from an 86 camaro. i don't know alot about buicks so im not sure what all is involved and what parts will interchange so if someone could let me know i would appriciate it. i will foward all info to them.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-20-2007, 11:14 AM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
Re: 1983 regal v6 to v8 swap questions
The engines will swap straight out pretty much. You need to either keep the frame mounts from the camaro or buy new ones (cheap and good insurance). You'll have to remove the b.o.p. mounts and use the other set of holes for the chev. mount. You'll have to re-route some wires because of the different locations of the starter and front accessories. If your old tranny is a overdrive the driveshafts and tranny mounts will all be the same. If not, you will either have to move the tranny mount backwards and drill some new holes or make a plate to adjust the mount position to fit the new longer tranny. You'll also need to get about a 3 inch shorter driveshaft (if i remember right). I used one out of a '78 Firebird. If you have any other specific questions let me know. I did a couple of these swaps on and '87 Cutlass and an '83 Cutlass a few years ago. Still have the '83, it's got a 75,000 mile combination from a '76 C20 2wd (350/350th) that'll roast the tires all day long.
Old 02-20-2007, 08:07 PM
ZL1power69's Avatar
GM S-Series Mod
great thanks. ill relay the info to him.
Low 11 sec sleeper
My Cardomain
Old 03-16-2007, 07:08 AM
sharkmonkey sharkmonkey is offline
I know this is an older thread but a quicker & cheaper swap is to use a Buick V8 350 instead. There is no wire or fuel line relocating and you can use the same frame pads and motor mounts that are in there now. Also, all of the accessories on your V6 will bolt on to the V8 like the Alt, AC, power steering, starter, etc. You can also use the 700r4 with a trans adapter plate or just keep the tranny you have now. It will bolt to the V8 with no adjustments. If you did go with the 700r4 you would most likely want to consider a rear end swap as well. Your current gear ratio (2.56 or 2.41:1) would be a dog with that transmission. A 3.23 or 3.42 would work better. And one more thing to consider, the Buick V8 puts out more low end torque than a Chevy motor.
Do what you want, these are just my opinions.
MARK
Mark "Sharky" Stover
73 Century Regal 455
05 Chrysler T&C
07 Dodge Ram SLT
11 GMC Yukon Denali XL
