Old 01-28-2007, 02:36 PM
thatwhitecrx thatwhitecrx is offline
wtf can someone help
i have a 91 crx that starts to hestitate at 5k rpm in 3rd gear also power lose? just changed plugs wires water pump timing belt. any suggestions?
Old 01-28-2007, 02:39 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: wtf can someone help
What model of crx and what motor do you have? Also are you running dpfi or mpfi? What upgrades do you have?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 01-28-2007, 02:41 PM
its a dx stock motor just an intake upgrade
Old 01-29-2007, 01:13 AM
4G4D Store's Avatar
Hmm, did you replace the parts after you noticed the power loss, or before, then notice after it you replaced them? I can't really think of how any of those would affect power loss.
Old 01-29-2007, 01:34 PM
i noticed it before i had the parts changed.
Old 01-29-2007, 06:15 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
how's everything else? smoke? oil lose? weird noises?
-tony-
2000 honda s2000
Old 01-29-2007, 10:24 PM
4G4D Store's Avatar
Does anybody know when the second (backup) injector is supposed to kick in - I'm wondering if it may not be kicking in, then again, that would throw a CEL. It's tough to say - I'd start with these things (if you've done them already, just disregard that item): Spark Plugs, Plug Wires, Distributor Cap & Rotor, fuel filter, run injector cleaner through the car, oil change, check your timing w/ timing light, make sure your ground wires from the engine to the chassis are good and secure. That's all I can think of right now.
Old 01-30-2007, 01:06 AM
any answers to the questions?
-tony-
2000 honda s2000
Old 01-30-2007, 09:45 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
He also said he replaced the timing belt. He may want to doublecheck the timing.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-30-2007, 10:37 AM
theres smoke every once in a while oil has always been burning quick as for weird noises um yeah theres a clinging/ rattlely noise but i cant tell where. sounds like the exhaust that happens when its warmed up.
Old 02-05-2007, 05:53 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
You might want to check your Distributor Rotor...i had the same problem when i first bought my car, and it ended up being a lose Rotor.
- Marlon
カーブのキラー
DigitalHorizon
Old 02-06-2007, 07:43 PM
viper-blue's Avatar
viper-blue viper-blue is offline
sounds like a valve
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 02-06-2007, 08:17 PM
Shoughun Shoughun is offline
Banned
Maybe you can to check again the plug wire connection... My brother had the same problem, it turns out it was just a loss connection in his GM Spark plug wires.Better check out ASAP..
Old 02-08-2007, 02:45 PM
jusg19 jusg19 is offline
If you got the advance auto, napa, auto zone crap wires take them back and spend like $5 more and go the the honda ones. I've always noticed that if you rund the cap, rotor, wires, with OEM the engine runs so much better than any aftermarket crap. Also, are your plugs shot? Are you running platnum? if you are with stock ignition you are killing your ignition because it was never ment to have to put out that type of juice to get the plat to spark. You are better off changing your plugs more often with stock ones than going plat and changing once every 100k (If your car was never ment to run plat)
Old 02-08-2007, 11:13 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
ok so have u resolved ur dilema yet?
