Old 01-28-2007, 12:51 PM
wicklands wicklands is offline
Radiator Replace
My daughter's boyfriend helped her fix a leak and now the top inlet to the radiator is crushed. My manual says nothing about replacing the radiator. I was wondering if it is a fairly normal effort or if there are some items that need to be moved or some difficult to reach bolts? I am just trying to guage how much time to allocate.
Thanks,
Steve W.
Old 01-28-2007, 01:03 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Radiator Replace
The radiator is pretty simple to remove. You will have i think 4 bolts on each fan to remove and 2 electrical plugs. Then ofcourse the hoses on the radiator. Then you just have I believe 4 bolts on the top that you have to remove and it slides right on out. You have to be careful on the hose necks on Honda radiators because they are usually pretty fragile unless you happen to get one thats metal.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-29-2007, 06:52 PM
ozzfreak ozzfreak is offline
Unless it's an automatic, then you have transmission lines too. I just changed mine last weekend. Also, my a/c hoses were kind of a pain, but it didn't work anyway, so I just unhooked them and left them off. I also think that there is only 2 bolts on the top of each fan, and the bottom part snapped down into place. Hope this helps.
Old 01-29-2007, 07:27 PM
Tony's Avatar
TLD Member #1
Well I didn't specify how many hoses because I didn't know if its an auto or not. Doesn't matter if its auto or not, it will have the necks at the bottom. As for the bolts on the fans, you might be correct, I haven't pulled the fans for awhile on these. Just the steps I usually go through on any car removing the radiator or fans.
Tony
Old 01-30-2007, 12:06 AM
Thanks for the tips. I ordered the parts but it looks like a post Super Bowl project.
Thanks Again,
Steve W.
Steve W.
http://www.automotiveforums.com/vbulletin/#
Loser
