Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-28-2007, 03:17 AM
SPRaYeD9 SPRaYeD9 is offline
Banned
replacing oil pan on malibu
has anyone replaced the oil pan on a 2001 chevy malibu? how hard is this to do? do you have to take anything apart to get to the oil pan? is it possible to do this with the engine in the car?
Old 01-28-2007, 04:30 AM
Banned
Re: replacing oil pan on malibu
would it be easier to just crash the car? or even, just set it on fire?
Old 01-28-2007, 02:01 PM
Banned
maybe i'll check the honda forum
Old 01-28-2007, 07:09 PM
bcopeland bcopeland is offline
Question - why do you need to replace the oil pan? Is there a hole in it?
Old 01-29-2007, 01:26 PM
CRASH IT CRASH IT is offline
Banned
Yes, it is cracked. I need to replace the oil pan and gasket. I cannot find my manual for anything.
Old 01-29-2007, 11:43 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
You need to remove your drivebelt, A/C compressor, exhaust manifold brace, radiator outlet pipe and thermostat, oil level sensor, plastic flywheel/driveplate inspection cover, and unclip the right front brake line from the frame. Also you may need to raise the engine and remove the engine mount strut and bracket from the front of the oil pan. Looks like too much work to try at home. I'd pay the dealership to do it.
By the way. I'm guessing you didn't read those guidelines to closely so here's another link to them. You need to re-read these parts.
MULTIPLE ACCOUNTS:
If through inappropriate behavior or not following the guidelines outlined in this document, your account is temporarily or permanently revoked, and you register another account, both accounts will be banned permanently. Multiple accounts/usernames are not allowed.
Warnings and Bannings: Not adhering to these guidelines can result in your account being temporarily or permanently banned. The length of the banning depends on the severity of the guideline broken. During temp bannings a member may not post under any other account. If this happens and it is discovered, all accounts belonging to that person will be banned permanently.
The following situations can possibly get you warned and or your account banned:
Making an Alias Account.
AF COMMUNITY GUIDELINES
