Old 01-28-2007, 01:22 AM
amphere amphere is offline
01 GTP not shifting into overdrive
I have an 01 GTP and it will not shift into overdrive. The transmission is smooth in the other gears. Is there a problem with the torque converter or could it be something else not allowing it to upshift?
Old 01-28-2007, 10:26 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 01 GTP not shifting into overdrive
Welcome to AF.
One thing you can do is get it scanned with a scan tool capable of reading out transmission related DTCs. That way you can see if it is a solenoid at the valve body like a 3-4 shift solenoid. However, the problem of no OD (4th) can be mechanical due to a bad 4th spline which is a common problem in a 4T65E autoransaxle.
Some TCC related DTCs may disable OD.
Timeslip 08/12/06
AF Community Guidelines
Old 01-30-2007, 08:59 AM
wht-tail wht-tail is offline
I second the bad spline. My 2000 GTP's overdrive went out at around 80K. The spline was actually smooth as a babies bottom.
Hope this helps.
