Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-27-2007, 09:31 PM
perbob29 perbob29 is offline
94 passport no shift
I have a 1994 passport that goes into reverse and also goes into 1st but wont shift to 2nd or higher. I know from reading some of these forums this seems to be an ongoing issue with these trucks. Also I'm having an issue with the brake light and rear anti lock light staying on. If anyone could help me resolve these issues. Please do.
Old 01-27-2007, 11:43 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: 94 passport no shift
Originally Posted by perbob29
I know from reading some of these forums this seems to be an ongoing issue with these trucks. .....
what did the posts say was the cause of the "ongoing issue"?
i'm assuming this is an automatic transmission. does it go thru the gears if you shift thru the gears manually with the gear shift? or are you saying it you can't move the gear selector other than P R N 1 ?
without further info, it sounds like the standard ole answer: the charging system, probably the alternator, but check the wires, the connectors, the grounds and especially first the connections at the battery.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-28-2007, 02:12 AM
the truck will shit through gears manually. Just won't automaticlly. I put brand termanels on it already I check to see if there was a broken wire but couldn't find one. The issue I was talking about is to due with the voltage and there are certian silionds that blow from what I have been reading. But I'm not sure I don't want to spend a fortune to fix it.
Old 01-28-2007, 09:47 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Solenoids don't "blow"... fuses blow. A solenoid will generally stop working due to voltage being too low for it to provide enough force to move whatever it is designed to actuate or it will fail when the coil itself swells enough to prevent movement. You, as trooperbc pointed out, likely have a low voltage problem. The Brake and Rear ABS lights and staying on can tend to indicate the beginning of the end for your alternator.
Old 01-28-2007, 12:16 PM
I ment sensors when I was talking about silionods . So what alternater do you guys recommend to replace it with
Old 01-28-2007, 01:57 PM
I had the alternater checked today. Registers 14.02 when running. I drove it to the shop to have tested and the following problems accured. The truck will shift trhough all gears when cold but will only shift into 1st and 3rd when hot. the check engine light comes on then goes off. The winter button does not respond at all. but power button does. All lights light up when I first turn the key. Any ideas
Old 01-28-2007, 02:10 PM
trooperbc's Avatar
...the check engine light comes on then goes off. ...
well that's a *good* sign, in a way. that means there is probably a code stored in the diagnostic system. do you know how to jumper the diagnostic connnector and read the codes yourself?
i would start there. you might also want to start doing some searching and researching on the automatic transmission gear selector mode switch/sensor (it goes by different names).
and...when they tested the alternator, did they do a test *under load*? if you don't know, find out. it could still be the alternator.
//bc
Old 01-28-2007, 02:14 PM
No I'm not sure how to do this.
Old 01-28-2007, 04:18 PM
trooperbc's Avatar
read this thread which also has links to other posts for a detailed description of how to read the codes
once you know where your diagnostic connector is for your rodeo. I don't know where yours is, someone chime in with location !
here's the link
http://www.automotiveforums.com/vbul...d.php?t=667340
//bc
Old 01-29-2007, 07:01 PM
I had the truck towed to ammcoo they are gonna do a full diagnostic on it and find out what the problem is with it. I will post whats going on as soon as I find out Thanks for the help so far perbob29
Old 01-29-2007, 09:20 PM
surferfletch surferfletch is offline
This is going to be interesting. $5 says they recommend a new tranny.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 01-29-2007, 09:32 PM
Ramblin Fever Ramblin Fever is offline
Sorry to say now, but I would NOT have chosen AAMCO - even if it didn't need a new transmission - they will tell you that you do.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-29-2007, 09:48 PM
trooperbc's Avatar
Ramblin Fever.... where is the CEL diagnostic connector on the 94 ?
and, yes just seeing the letters aamco gets one to squirm. my bet after rereading is, if its not the alternator, then it is the mode switch/sensor, and my bet is that a transmission shop is not even going to test it.
//bc
Old 01-30-2007, 12:11 AM
Sorry, Trooperbc, forgot to answer that before, I meant to.
The CEL connector is under the dash, just under the latch to pop the hood, drivers side, left of steering wheel.
No, I personally know for a fact AAMCO does not test the mode sensor OR the alternator - they tried to pull the $3k dollar crap on my tranny some 7yrs and 95k miles ago, when all it was was a faulty range mode sensor.
1997 3.2L V6 Rodeo
Old 01-31-2007, 03:50 PM
update So far they have pulled 8 different codes and found three bare wires in the truck. They are running a couple more test to figure out what is happing I will keep yous updated as I get the reports. Thanks agian perbob29
