Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 09-28-2002, 10:56 AM
opulent50 opulent50 is offline
Electrical problem 1993 Royale
My 93 Royale's gas gauge starts to go haywire when it gets down to a 1/4 tank of gas. Prior to this problem the computer failed, the cause I believe to be a short in the system. The fuel pump stopped working, was one of the results from the computer. I have replaced the fuel pump and checked all the grounds that I know about. I have started to suspect the gauge. Does anyone have any idea what may be causing this problem.
Thanks
opulent50
Old 01-29-2004, 09:08 PM
OldsmobileKid OldsmobileKid is offline
When the fuel pump was replaced, the pump and the fuel level float & sender could have been damaged. Check the wiring in and around the fuel tank, the guage itself is only reacting to the signal from the float & sender in the gas tank. The fuel level float & sender should be replaced if you don't find any other problems.
Good Luck!!
Old 01-30-2004, 09:27 PM
greengumby greengumby is offline
Re: Electrical problem 1993 Royale
thats defenitly the sednding unit
usually when replacing the fuel pump you shudda replaced the sending unit also since it's a "attached unit" it's starting to fail
Do it safely
Happy Motoring
