Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-27-2007, 03:48 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
HELP ASAP! Missing balancer belt!!!!!!!!!
Many of you know I am in the process of putting a built head on my car. Well I took off the lower timing belt cover today and noticed something strange. The balancer belt is not there! I ended up finding it snapped somewhere else in the engine bay. I had no idea my belt snapped how fucked am I?
This had to happen sometime between now and my last head gasket change. I remember hearing a belt squeeking awhile ago on startup but I figured it was the ac belt because, I could not get it tight. My car had a mysterious coolant problem where it would push the coolant out of the system into the overflow bottle. I ended up running no thermostat for awhile and it was cooling fine but coolant was still getting pushed out. I figured this was from a cracked/warpped head from a massive overheating I had. I didn't worry about it to much because, I was getting a head built anyway. My car also had a pretty good oil leak but, I am almost positive this was from me tighting the valve cover down too hard...way to hard.
My car didn't drive any differently other than it drove like shit before it got warmed up. Can I just throw another belt on there and be on my way or am I seriously fucked here?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 01-27-2007, 04:02 PM
NateS's Avatar
Re: HELP ASAP! Missing balancer belt!!!!!!!!!
Okay I calmed down a little bit. I just read on FAQ that if the balancer belt snaps the worst that can happen is the pieces hit the timing belt and make it snap/jump. If not then the motor just becomes more "buzzy". For some reason I did not notice the "buzziness" and as far as I know the T-belt did not skip(no loss of performance/bent/broken valves).
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-27-2007, 05:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I wouldn't worry about it. Its just like running the car with the balance shaft elimination kit.
95 Talon TSI AWD
97 Eclipse GST
Old 01-27-2007, 06:11 PM
NateS's Avatar
Well, thats what I thought at first too but, I read a post the Kevin made awhile back and he said that you can run with the front shaft in and no belt but, you need to remove the rear shaft(spins off of oil pump). He said that running no belt with both still installed is a "no-no" Can anyone comfirm this? Any suggestions? I just looked at instructions for installing the eliminator kit and it looks pretty difficult.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-28-2007, 09:49 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
The actual installation of the kit isnt too bad with the motor out of the car. Doing it while the motor is still in seems like it would be a pain.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 01-28-2007, 10:05 PM
NateS's Avatar
Yeah it deffinatly does. I've been reading up on the installation of it for the past couple days and I've decided to just replace the belt. I think it will be too much of a hastle with the block still in the car and on top of that I will be switching over to a 6 bolt adventually anyway. The one thing that makes me extremely nervous is figuring out what made the belt snap. The motor was rebuilt about 50K miles ago and I am asuming they replaced the balance shaft belt too. Then again it was a dealership job.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-28-2007, 10:09 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Anyone ever seen balance shafts? They look silly. I wouldnt do a BS elim unless the engine was out of the car. My DSM has a BS elim and its not annoying at all, makes me wonder why they put them there in the first place.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-28-2007, 10:30 PM
Yeah they are pretty fucked up, they don't even really do much at all, just more shit to break I guess. If you're eventually going to do a 6-bolt swap then I'd just put in a new belt and run it like that.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 06:00 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
before i rebuilt my engine i drove mine around with the balance shaft belt broke for about 1 year. Your better off without that belt anyways, they break more often than you know lol. So when i built my engine i also put the elim. kit in mine. I would be willing to bet alot of people that have modded there cars on here have that belt broke. If you do not check for it chances are it usually is after modding. The heavy launches is what usually breaks them. Do not replace that belt, run it without it.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 01-29-2007, 03:07 PM
NateS's Avatar
Talon69, That is what I wanted someone to tell me haha. But, like I said I read a post where Kevin said that you SHOULD NOT run no belt on the front BS unless you have removed the rear BS. So in other words if the rear BS is there you better be running a belt for the front. It would be nice to get Kevin's words here or something of the sort. What is the draw back of me running no belt with both shafts still in? Will it drop my oil pressure alot or what?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-29-2007, 03:30 PM
NateS's Avatar
I just read up on dsmtuners and the only post I found about running with no belt says that not running the belt will cause horrible vibrations. Like I said I ran without the belt for probably a few months and had no idea that it wasn't there(no noticable vibrations). Right now I'm leaning towards not replacing the BS belt and leaving both BS shafts in.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-29-2007, 04:19 PM
I've never seen nor had "horrible" vibrations when removing the balance shafts. It's something that "could" happen but never really does. You may get a tiny bit of vibration, but nothing really noticeable.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 05:29 PM
NateS's Avatar
I am not talking about removing the balance shafts. I am talking about leaving both shafts in and not putting a belt on the front shaft. I have heard that not putting a belt on the front BS shaft (rear shaft still installed) and runing it can mess with the oil pressure slightly.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-29-2007, 05:36 PM
That's what I meant, running them with no belt will give you the same "vibration" effect as completely removing them, so the vibration is nothing to worry about, that's all I was getting at.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 05:39 PM
NateS's Avatar
Oh okay cool. Misunderstanding on my part. So if I can just not run the belt why don't more dsmers do this? I am intending on completeing the timing job/head install without the BS belt installed... I'll let you all know how it goes. Thanks for all the info.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
