Old 01-27-2007, 03:20 PM
boatbuster boatbuster is offline
Awd Tow Button?????
I bought a 2002 AWD in August of 06. My first AWD, always had rear wheel drives in the past. Can anybody tell me what the "TOW" button does in the shifter lever? I looked in the manual and it only tells me to use it when towing at low speeds. Does this button put my transfer case in low mode or something like that???
Thanks for any help!
Old 01-27-2007, 03:30 PM
old_master's Avatar
Advisor/Moderator
Re: Awd Tow Button?????
When the tow/haul button is pushed in, a light on the dash will come on, (Tow/Haul), the shift points are raised, and the torque converter will not lock up.
Old 01-27-2007, 08:50 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Which is a good thing, the locking torque converter was designed by some idiot who lives at sea level and never fully loads his vehicle, let alone tows a trailer. when i had my 86 Safari tranny rebuilt the shop put in a Ford torque converter to avoid the lockup. be glad GM came up with a way to cancel the lockup, my Astro would lockup and drop to 30 mph in a 65 mph zone going over the pass when fully loaded or towing.
never, ever, let the quick lube guys talk you into a tranny flush or a filter and fluid change. take it to a reputable tranny shop and get their opinion.
Old 01-28-2007, 01:38 PM
Blue Bowtie's Avatar
Registered Offender
In addition, line pressure in lower ranges is raised slightly to hold clutches more firmly, and the TCC will eventually lock, but only at ridiculously low load values and higher speeds. You really don't want to operate in that mode if it isn't necessary, since the trans will also run hotter.
The 1986 ECM programming left a lot to be desired in TCC management. They were a lot better just a couple yeas later.
