water noises from under car
i have water noises coming from under my console. it makes a girgling sound when i rev up the engine.....what is it from?
Re: water noises from under car
what yr? when was last time u check coolant level?
could be from heater core area. any moisture around sides of front center consol? (use a towel to wipe thru carpet) |
it's an 05'. there is no moisture around the car and the carpet is dry. all my fluids check out ok. it started a day after we had real heavy rains. what else could it be?
was noise exist when car runs on hwy/freeway?
Or it happens only when it's parked and reving? What is your maintainance history? |
Air pocket in your heater core , will give you a water sounding noise. Have coolant system Bleed , If you have an 05 with under 36k miles it is under warranty.. GL
