Old 01-26-2007, 11:48 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Lightbulb civic distributors
ok so ive really started to notice civic distributors are absolutely problem ridden. my first one kinda crapped out and cause and extreme timing advance just packing fuel into my cylinder and my dizzy now had the center shaft freeze. has anyone else has bad luck with these stupid things.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 01-27-2007, 02:24 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: civic distributors
yeah there are lots of problems with them. but nothing that cant be fixed with the matching obd distributor. simple swaping of parts
Old 01-27-2007, 10:21 AM
i figured as much. i gotta track down a new si dizzy so i can have a car.
06 cbr 600 f4i
91 civic hatchback.
Old 01-27-2007, 10:53 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
I've actually taken perfect working distributers off to pull the motor, set them down on a shelf, and had them not work when I put them back on. Apperantly they just decide to work when it's convienent for them.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-27-2007, 08:19 PM
why did honda make them so shotty does anyone have any ideas. i jsut picked up a reman unit but it blew a hole in my pocket 200 bones.
06 cbr 600 f4i
91 civic hatchback.
Old 02-04-2007, 08:52 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
heh... if you're running a 4th gen, all the dizzy's are the same... the only diff is when you use a DPFI dizz for a MPFI setup... you need to "add" the CPS... have fun with that.. I've never tried it.. been told it can be done... but before you start buying stuff for your "Si"... make sure HF or other parts won't fit it.
The HF dizzy WORKS PERFECTLY with the MPFI swap... there is NO DIFFERENCE IN THE PARTS... NOT EVEN IN THE COILS.
Old 02-05-2007, 12:10 AM
well price im sure for the hf and si dizzy are about the same. as for adding shit to a dpfi dizzy. why bother those thigns new or rebuild cost more then the si ones do. and anything used in the dizzy department is unreliable. or more trouble then its worth. as for me well ill keep to my dx convert. with crx si parts.
06 cbr 600 f4i
91 civic hatchback.
