engine maintenance light
hi everybody....
I think i`ve got a little problem here.... today while driving my engine maintenance light went on....could anyone tell me what that could have been caused by? Is it the engine or just some kind of maintenance that it requires??? Please help..... |
Re: engine maintenance light
note: after about 12 hours of sitting in the driveway the light went off....but im afraid its going to go back on.....so....does anyone have any suggestions on what it can be???
thanks alot in advance ppl Yuriy |
It could be a number of reasons. The simplest is the gas cap not tight. If it appears again I would have it checked by a dealer or someone with a scan tool.
and how much will scan test cost me at the dealership?
should be half hour to an hour labor depending on dealer. You can also check your area for an independent shop that specializes in German cars.
What year is the car? If it's 89-94 you can figure out code on your own see below.
BMW DIAGNOSTIC TROUBLE CODES (DTC) All 1989-94 BMW vehicles are equipped with a self diagnostic system for the detection of injection faults. When a fault is detected by the system the Electronic Control Unit (ECU) records the code corresponding to the defect in the ECU's memory until either: MOTRONIC 'PEDAL' FAULT CODES (CARB) MOTRONIC INTERNAL TROUBLE CODES DME 1.1, 1.2, 1.3 DME 1.7, 1.7.1 & 3.1 DME1.7.2 DME 3.3 DME 3.3.1 DME MS40 DDE 1 DDE 2 SUPPLEMENTAL RESTRAINT SYSTEM (AIRBAG) CODES SRS 1 SRS 2 SRS 3 SPECIAL NOTE ON E24 & E30 SRS SYSTEMS ELECTRONIC TRANSMISSION CODES EGS 1.XX EGS 1.XX Late Model EGS 2.28 EGS 4.XX EGS 7.XX EGS 9.XX BMW MOTRONIC 'PEDAL' FAULT CODES (Models 1989-94) All 1989-94 BMW vehicles are equipped with a self diagnostic system for the detection of injection faults. When a fault is detected by the system the Electronic Control Unit (ECU) records the code corresponding to the defect in the ECU's memory until either: 1) The vehicle battery or the ECU is disconnected. 2) The engine is started 60 times with no recurrence of the fault. 3) The ECU memory is cleared using the Bosch KTS300, CARSOFT BMW software or the CS1000 BMW hand scanner. To review the FAULT CODES from the ECU memory use the following procedure: 1) Turn the ignition switch to the 'engine run' position. 2) Depress the gas pedal to the floor 5 times. 1 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm The CHECK ENGINE light will blink out the FAULT CODES starting with the lowest number first. These FAULT CODES consist of 4 digits each separated by a short pause (ie. blink pause blink blink pause blink pause blink translates as 1 2 1 1). CODE MALFUNCTIONING SYSTEM EXPLANATION 1211 DME Control Unit This code is stored when the DME self test fails. Delete any stored codes. Start and run the car for 30 seconds. Turn off the ignition for 30 seconds. Rerun the diagnosis. If the same fault recurs, the DME control unit must be replaced. 1212 Lambda (O2) Sensor 2 This code is stored when the engine temperature is >70C and the Oxygen Sensor value is out of range or not present. Check the Oxygen Sensor wiring and the operation of the sensor. The value should fluctuate between 0.02 and 0.85V. Slow fluctuation indicates a polluted Oxygen sensor and negative values indicate a damaged sensor. Note: Cars without Catalytic Convertors will incorrectly store this code. 1213 Lambda Control 2 This code is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds. Possible causes: Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure (Spark plugs,, compression, intake/exhaust valves, ...etc.) 1215 Air Mass/Volume Sensor This code is stored if there is a break or short-circuit at: Air Mass Flow Meter or its supply wires or the voltage supply to Air Mass Flow Meter insufficient. Cable damage is the most common cause of this trouble code. 1216 Throttle Potentiometer This code is stored if a break or short-circuit occurs in the wiring to the Throttle Potentiometer or the potentiometer is defective. Damage at the throttle potentiometer connection is the most common cause of this fault. 1218 Output Stage, Group 1 This code is stored if there is a short to B+ or Ground at the Output Amplifier Stage (Bank 1). Generally this code occurs with other defects. Causes may be a faulty Idle Speed Actuator, Injector Valves, Ignition Coil on Plug, Oxygen Sensor Heating Relay, Fuel Evaporation, Control Valve, Malfunction Indicator Lamp (MIL) and/or EKP Relay. Delete the code after examining for other faults. If the code recurs, delete code, then disconnect the DME for a minimum of 5 minutes to initiate a reset. Rerun car. If code recurs and no other defects are found the DME is most likely damaged and must be replaced. If the code does not recur and the engine runs properly, ignore. 1219 Output Stage, Group 2 This code is stored if there is a short to B+ or Ground at the Output Amplifier Stage (Bank 2). Generally this code occurs with other defects. Causes may be a faulty Idle Speed Actuator, Injector Valves, Ignition Coil on Plug, Oxygen Sensor Heating Relay, Fuel Evaporation, Control Valve, Malfunction Indicator Lamp (MIL) and/or EKP Relay. Delete the code after examining for other faults. If the code recurs, 2 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm delete code, then disconnect the DME for a minimum of 5 minutes to initiate a reset. Rerun car. If code recurs and no other defects are found the DME is most likely damaged and must be replaced. If the code does not recur and the engine runs properly, ignore. 1221 Lambda (O2) Sensor 1 This code is stored when the engine temperature is >70C and the Oxygen Sensor value is out of range or not present. Check the Oxygen Sensor wiring and the operation of the sensor. The value should fluctuate between 0.02 and 0.85V. Slow fluctuation indicates a polluted Oxygen sensor and negative values indicate a damaged sensor. Note: Cars without Catalytic Convertors will incorrectly store this code. 1222 Lambda Control 1 This code is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds. Possible causes: Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure (Spark plugs,, compression, intake/exhaust valves, ...etc.) 1223 Coolant Temp. Sensor This code is stored when a short to plus or a break in the wiring at the Coolant Temperature Sensor or its supply wires may exist. Check the wiring and the value of the sensor. 8.26-10.56 KOhms at -10C, 2.2-2.7 KOhms at 20C, 290-364 Ohms at 80C 1224 Intake Air Temp. Sensor This code is stored when a short to plus or a break in the wiring at the Intake Air Temperature Sensor or its supply wires exists. Check the value of the sensor. 2.2-2.7 KOhms at 20C, 760-910 Ohms at 50C 1225 Knock Sensor 1 This code is set when Knock Sensor #1 has sent multiple signals or a break or short has occurred in the sensor or it's wiring. Check the Knock Sensor and its wiring for defects. Check with customer about the grade of fuel being used (RON>91). Increase octane if necessary. (Caution customer about carbon build up.) 1226 Knock Sensor 2 This code is set when Knock Sensor #2 has sent multiple signals or a break or short has occurred in the sensor or it's wiring. Check the Knock Sensor and its wiring for defects. Check with customer about the grade of fuel being used (RON>91). Increase octane if necessary. (Caution customer about carbon build up.) 1227 Knock Sensor 3 This code is set when Knock Sensor #3 has sent multiple signals or a break or short has occurred in the sensor or it's wiring. Check the Knock Sensor and its wiring for defects. Check with customer about the grade of fuel being used (RON>91). Increase octane if necessary. (Caution customer about carbon build up.) 1228 Knock Sensor 4 This code is set when Knock Sensor #4 has sent multiple signals or a break or short has occurred in the sensor or it's wiring. Check the Knock Sensor and its wiring for defects. Check with customer about the grade of fuel being used (RON>91). Increase octane if necessary. (Caution customer about carbon build up.) 3 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 1231 Battery Voltage/DME Main Relay Either the battery was disconnected or the voltage of the battery is too low or too high. Check the battery and charging system. 1232 Throttle Idle Switch 1233 Throttle WOT Switch 1234 Vehicle Speed Sensor (Speedometer A Signal) This code is stored when no plausible speed signal is detected while driving. The requirements are an engine speed >2500 rpm and under load for more than 10 seconds. Check the speedometer function and the wire to the DME . Also check for codes in the Combi Unit (Instrument Cluster). 1237 A/C Compressor cut off This code is stored if there is a short to B+ or Ground. In the case of a short to ground, the A/C compressor is not switched off at a speed below 5 mph (8 km/h) when accelerating under full load. The A/C compressor does not operate when shorted to B+. Check the A/C compressor cut-out relay and its wiring. 1241 Air Mass Sensor (See note 1) 1242 A/C Compressor Check A/C compressor signal wire to the DME control unit for a short-circuit to power, ground or for disconnection. Check refrigerant level and condition of A/C pulley drive belt. 1243 Crankshaft Pulse Sensor This code is stored when signal from the Crankshaft Pulse Generator is implausible (absent or out of range). Check the Crankshaft Pulse Generator and the wiring. 1244 Camshaft Sensor This code is stored when the Camshaft Pulse Generator signal is interrupted or defective. Also check the spark plugs and the ignition coil(s) output. Check the pulse signal with an oscilloscope (50Hz, 25ms sweep). Measure with a break-out box. If a coil is found to be defective the DME control unit may also be damaged. Failure of the injector side of the output stage is the most common symptom. 1245 Intervention EGS This code is stored when a short to ground occurs on the wire from the EGS to the DME control unit, for more than 2.5 seconds. The on-board computer should display the message TRANSMISSION EMERGENCY PROGRAM. Ignition timing will be retarded only once and then the DME will substitute the original value until this code is cleared. Check the wire and connection to the EGS. 1247 Ignition Secondary Monitor 1251 Fuel Injector 1 (or group 1) Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1252 Fuel Injector 2 (or group 2) Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1253 Fuel Injector 3 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is 4 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm intermittent. 1254 Fuel Injector 4 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1255 Fuel Injector 5 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1256 Fuel Injector 6 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1257 Fuel Injector 7 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1258 Fuel Injector 8 Check the injector valve for coking and proper spray pattern. Check the wiring from the DME and the output stage of the DME. Code 1283 may also be stored when the defect is intermittent. 1261 Fuel Pump Relay Control There is a break or short circuit in the wiring to the Fuel Pump Relay, pin 3, of the DME or the output stage in the DME is damaged (M1.3 only). 1262 Idle Speed Actuator There is a break or short circuit in the wiring to the idle actuator or the wire from the DME is defective or the output stage in the of the DME is damaged. This code will also be stored if the engine stalls at over 600 rpm. 1263 Purge Valve This code is stored if there is a break or short-circuit at: Evaporative control valve, wire from the DME control unit or the output stage of the DME control unit is defective (M1.3 only). 1264 Lambda (O2) Sensor Heater This code is stored if there is a break or short-circuit at:, - Oxygen Sensor Heater, - Sensor heating relay, - Wire from the DME control unit. Check the Oxygen Sensor Heater Relay and Air Pump Relay and the supply wires. 1265 Fault Lamp (check engine) This code is stored if a break or short-circuit occurs in the wiring to the Malfunction Indicator Lamp (MIL) or the lamp is burned out. 1266 VANOS Relay Check the wires and the connections of the VANOS relay (Variable camshaft adjustment). The relay could also be defective. 1267 Air Pump Relay Control 1271 Ignition Coil 1 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1272 Ignition Coil 2 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 5 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 1273 Ignition Coil 3 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1274 Ignition Coil 4 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1275 Ignition Coil 5 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1276 Ignition Coil 6 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1277 Ignition Coil 7 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1278 Ignition Coil 8 A break or short in the Ignition Final Stage wiring has occurred. Check primary ignition signal pattern. 1281 Control Unit Memory Supply This code is stored when a defect is detected in the RAM or in the ROM/EPROM. This is most often the result of low battery voltage. Delete the stored codes and disconnect the DME for at least 5 minutes in order to trigger a reset. Reconnect the DME and run the engine at idle for 3 minutes then drive the car at over 30 mph for more than 5 minutes. If the code recurs the DME must be replaced. 1282 Fault Code Memory This code is set if there is illogical data stored in the trouble code memory. Delete the stored codes. Simulate a defect (i.e. start engine and then disconnect the Idle Actuator) If the code recurs, the DME control unit must be replaced! 1283 Fuel Injector Output Stage This code is stored when a break or short-circuit occurs temporarily at: an injector valve, wiring from the DME to an injector or the injector stage of the DME is damaged. 1286 Knock Control test Pulse The ECU internally generated pulse was not detected. It is used to verify electrical integrity (shorts or disconnection) of the knock control circuitry both internally and externally. Check wiring and Knock Sensors. 1444 No Failures *In the 12 cylinder model the Injection system is treated as two 6 cylinder systems joined at the crank. This means there are two ECUs in the system. To access the second ECU depress the gas pedal to the floor 6 times.Some models will return implausible blink codes if the ECU has failed or if the power is interrupted during operation. Removal of the control units harness and reconnection after 10 minutes seems to resolve most of these problems. Note 1) Code 41, 1241 and 2241 can be false Air Mass Flow Meter codes on 1992 and later models. The actual cause of the code is a faulty Idle Air Valve and the need for an updated EPROM. See all applicable service bulletines for further information. 6 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DME 1.1, 1.2, 1.3 M20, M30, M40, M70, S38 FAULT MALFUNCTION 1 Fault in the DME control Unit - Reset and run vehicle if code returns replace DME. 3 Electrical Fuel Pump Relay (EKP) 4 Idle-speed Actuator - Open 5 Tank Ventilation Valve 7 Air-flow Sensor 10 Lambda Regulation 15 Check Engine Failure Light 16 Injection Valve(s) 17 Injection Valve(s) 22 Idle Speed Controller 23 Lambda Sensor - Heater/Air Pump 28 Lambda Sensor 29 Speed Signal 33 Magnetic Valve Hydraulic Automatic Transmission 37 Power Supply 38 ASC/DWA 40 Air Conditioner Compressor 43 Idle-speed Co-potentiometer 44 Temperature-sensor - Air Intake 45 Temperature-sensor - Coolant 50 Engine Towing Moment Regulation 51 Ignition Angle Engagement 52 Idle-speed Switch 53 Wide-open-throttle Switch 54 Torque Converter Lockup Clutch 100 DME Control Unit Final Stage 7 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DME 1.7, 1.7.1 & 3.1 M40, M42, M50, S70 FAULT MALFUNCTION 0 Undefined Fault 1 Fuel Pump Relay (EKP) / RPM Signal 2 Idle Speed Controller 3 Fuel Injector on Cylinder # 2+4+6 or # 8+10+12 8 Fault Lamp (US Model only) 12 Throttle Valve Potentiometer 15 Knock Sensor 1 16 Ignition, #6 or #12 Cylinder Spark Signal 18 Control Unit, Pin 18 Stage (when short) 29 Idle Actuator 32 Fuel Injector, Cylinder 1+3+5 or Cylinder 7+9+11 36 Tank Ventilation Valve 37 Oxygen Sensor Heater 41 Air Flow Sensor (See note 1 page 14.) 42 Knock Sensor 2 48 Air Conditioner Compressor Cutoff 54 Control Unit Power Supply B+ 55 Ignition, #1 & #4 cylinder 63 Transmission Road Signal (in P or N) 64 Ignition Timing Intervention (signal from EGS) 70 Oxygen Sensor 73 Vehicle Speed Sensor Signal 76 Idle CO Potentiometer 77 Temperature Sensor - Air Intake 78 Temperature Sensor - Engine Coolant 82 Intervention, Engine Drag Torque Control (MSR) 83 Intervention, Automatic Stability Control (ASC) 85 Air Condition Compressor 100 This Code Pinpointed Elsewhere 153 Control Voltage of Knock Control 200 Control Unit (RAM, ROM/EPROM) 201 Oxygen Sensor Control 255 Control Unit Internal Fault 8 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DME1.7.2 M42, M43 Engine FAULT MALFUNCTION 0 Undefined fault 1 Fuel pump relay (EKP) 2 Idle Speed Controller 3 Fuel Injector #1 & #3 cylinder 8 Fault Lamp (US model only) 12 Throttle Valve Potentiometer 15 Knock Sensor 1 16 Camshaft Sensor 18 Changeover Valve, DISA Butterfly 29 Idle Actuator 32 Fuel Injector, #2 & #4 cylinder 36 Tank Ventilation Valve 37 Oxygen-Sensor Heater 41 Air Mass Flow Sensor (See note 1 page 14.) 42 Knock Sensor 2 48 Air-Conditioner Compressor Cutoff 54 Control-Unit Power Supply B+ 55 Ignition, #1 & #4 cylinder 64 Ignition Timing Intervention (signal from EGS) 70 Oxygen Sensor 73 Vehicle Speed Sensor Signal 76 Idle CO Potentiometer 77 Temperature Sensor - Air Intake 78 Temperature Sensor - Engine Coolant 85 Air Condition Compressor 100 This code pinpointed elsewhere 153 Control Voltage of Knock Control 201 Oxygen Sensor Control 255 Control Unit Internal Fault DME 3.3 M60, S38, S50 FAULT MALFUNCTION 0 Undefined Fault 1 Fuel Pump Relay (EKP) 2 Idle Actuator Closing Winding 3 Fuel Injector, #1 Cylinder 4 Fuel Injector, #4 Cylinder 5 Fuel Injector, #6 Cylinder 6 Fuel Injector Output Stage without Cylinder 9 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Assignment 7 Fuel Injector, #7 Cylinder 8 Fault Lamp (US Model only) 12 Oxygen Sensor #2 13 Oxygen Sensor #1 15 Ignition Circuit Monitoring 16 Crankshaft Pulse Generator 17 Camshaft Sensor 18 Fault to test storage - No actual fault 22 Ignition #7 Cylinder 23 Ignition #6 Cylinder 24 Ignition #4 Cylinder 25 Ignition #1 Cylinder 26 Control Unit Supply B+ 29 Idle Actuator Opening Winding 31 Fuel Injector, #5 Cylinder 32 Fuel Injector, #8 Cylinder 33 Fuel Injector, #3 Cylinder 35 Fuel Injector, #2 Cylinder 36 Tank Ventilation 37 Oxygen-Sensor Heater #2 38 Oxygen-Sensor Heater #1 41 Air Mass Flow Sensor (See note 1 page 14.) 42 Road Speed Sensor 46 Free SG Output Stage 48 Air Conditioner Compressor Cutoff 49 Ignition, #2 Cylinder 50 Ignition, #3 Cylinder 51 Ignition, #8 Cylinder 52 Ignition, #5 Cylinder 54 DME Control Unit Power Supply via Main Relay 55 Ignition Final Stage 62 Signal, Electronic Engine Power Control (EML) 63 Torque Convertor Lockup Clutch 64 Engagement in the Ignition Control Unit 65 Air Conditioner Compressor 66 Signal, Burglar Alarm System (DWA) 67 Knock Sensor Cylinder #4 68 Knock Sensor Cylinder #3 69 Knock Sensor Cylinder #2 70 Knock Sensor Cylinder #1 73 Throttle Valve Potentiometer 76 Idle CO Potentiometer 77 Temperature Sensor - Air Intake 10 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 78 Temperature Sensor - Engine Coolant 82 Intervention, Engine Drag Torque Control (MSR) 83 Intervention, Automatic Stability Control (ASC) 85 Air Conditioner Compressor Relay 100 Output Amplifier Stage - Group 1 101 Output Amplifier Stage - Group 2 200 DME control Unit 201 Oxygen Sensor Control #1 202 Fault Memory in Control Unit Fault 203 Oxygen Sensor Control #2 204 Idle Speed Increase During MSR Operation 205 Transmission Intervention during Gear-Shifts (EGS only) 206 Knock Regulation 210 CAN Interface, Trans. Intervention Version DME DME 3.3.1 (VANOS) M50 FAULT MALFUNCTION 0 Undefined Fault 1 Fuel Pump Relay (EKP) 2 Idle-Actuator Closing Winding 3 Fuel Injector, #5 Cylinder 4 Fuel Injector, #6 Cylinder 5 Fuel Injector, #4 Cylinder 6 Fuel Injector output stage without cylinder assignment 7 VANOS Solenoid Valve 8 Fault Lamp (US Model Only) 12 Oxygen Sensor #2 13 Oxygen Sensor #1 15 Ignition-Circuit Monitoring 16 Crankshaft Pulse Generator 17 Camshaft Sensor 23 Ignition, #4 Cylinder 24 Ignition, #6 Cylinder 25 Ignition, #5 Cylinder 26 Control-Unit Supply B+ 29 Idle-Actuator Opening Winding 31 Fuel Injector, #3 Cylinder 32 Fuel Injector, #2 Cylinder 33 Fuel Injector, #1 Cylinder 36 Tank Ventilation 11 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 37 Oxygen-Sensor Heater 41 Air-Mass Flow Sensor (See note 1 page 14.) 42 Vehicle Speed Sensor 48 Air-Conditioner Compressor Cutoff 50 Ignition, #1 Cylinder 51 Ignition, #2 Cylinder 52 Ignition, #3 Cylinder 54 DME Control-Unit Power Supply via Main Relay 57 Ignition Timing Intervention (signal from EGS) 62 Signal, Electronic Engine Power Control (EML) 66 Signal, Burglar Alarm System (DWA) 69 Knock Sensor 2 70 Knock Sensor 1 73 Throttle Valve Potentiometer 77 Intake Air Temp Sensor 78 Engine Temp Sensor (coolant) 82 Intervention, Engine-Drag-Torque Control (MSR) 83 Intervention, Automatic Stability Control (ASC) 100 Output Stage, Group 1 101 Output Stage, Group 2 200 DME Control Unit (RAM, ROM/EPROM) 201 Oxygen Sensor Control 202 Fault Memory in Control Unit 204 Idle Speed Increase during MSR Operation 206 Knock Control Test Pulse 12 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DME MS40 (Siemens) FAULT MALFUNCTION 1 Ignition Fault - Cylinder #1 2 Ignition Fault - Cylinder #3 3 Ignition Fault - Cylinder #5 5 Injection Valve Fault - Cylinder #6 6 Injection Valve Fault - Cylinder #4 10 Air-conditioner Compressor 12 Speed Signal 14 Transmission Engagement 22 Injection Valve Fault - Cylinder #3 23 Injection Valve Fault - Cylinder #1 24 Air Conditioner Compressor 27 Idle-speed-controller 29 Ignition Fault - Cylinder #2 30 Ignition Fault - Cylinder #4 31 Injection Valve Fault - Cylinder #6 33 Injection Valve Fault - Cylinder #5 49 Power Supply Control Unit 50 Injection Valve Fault - Cylinder #2 51 Tank Ventilation 52 Fuel Pump 53 Lambda Sensor - Heater 62 Ignition Signal Information 63 Knock Sensor Fault - Cylinder #4, 5 and 6 64 Knock Sensor Fault - Cylinder #1, 2 and 3 68 Air-flow Sensor (Hot Film) 75 Voltage at the Lambda Sensor 77 Throttle Potentiometer 79 Camshaft Angle Pulse Generator 81 Temperature Sensor - Engine Coolant 84 Camshaft Angle Pulse Generator 85 Temperature Sensor - Air Intake 97 Tank Ventilation Valve 98 Idle Speed Controller 99 Lambda Control 100 Control Unit Fault 13 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DDE 1 Digital Diesel Electronics Version 1 FAULT MALFUNCTION 1 RPM Transmitter 2 Temperature Sensor - Fuel 3 Temperature Sensor - Engine Coolant 4 Pedal Position Transmitter 5 Boost Pressure Sensor 6 Throttle Position Potentiometer 7 Boost Pressure Regulator 8 Air Mass Position 10 Speed Regulator 11 Compute Coupling 12 Temperature Sensor - Air 13 RPM Data Line 14 Start of Injection Transmitter 15 Exhaust Gas Recirculation 16 Start of Injection Regulator 17 Brake Test Switch 36 Water Level Sensor Transfer interrupted! ="Arial,Helvetica">45 14 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm DDE 2 Digital Diesel Electronics Version 2 FAULT MALFUNCTION 0 Undefined Fault 1 Air Mass Positioner 3 Electronic Turn off Unit 5 Start of Injection Transmitter 6 Glow Period Regulator 10 Start of Injection Regulator 15 Voltage Supply DDE Control Unit 20 Speed Regulator 21 Throttle Position Potentiometer 28 Clutch Switch 29 Speed Signal 31 Brake Switch 35 Temperature Sensor - Fuel 36 Water in Fuel Sensor 37 Pedal Position Transmitter 41 Glow Period Regulator Theft Protection System 47 RPM Transmitter 52 Temperature Sensor - Charge Air 53 Temperature Sensor - Engine Coolant 54 Boost Pressure Sensor 56 Internal Control Unit Fault 58 Disturbance of the High-level Stage 59 Deviation of the Boost Pressure Supplemental Restraint System Codes (SRS/Airbag) ***** BEFORE STARTING TO WORK ON THE SRS SYSTEM ***** DISCONNECT THE BATTERY SRS 1 (1988-91) CODE DESCRIPTION OF MALFUNCTION 1 AIRBAG IGNITION CAPACITOR DEFECT. - Please replace the Ignition Capacitor. The airbag system will not function if this is not corrected. 2 DIAGNOSTIC UNIT MALFUNCTION - Examine all faults and delete them from the fault memory. If this fault recurs you must replace the SRS Control Unit. 3 AIRBAG SUPPLY WIRE- DRIVERS SIDE -Resistance Too High - Please check the wire resistance. If necessary replace the cable set. 4 AIRBAG SUPPLY WIRE - DRIVER SIDE - POWER SUPPLY DEFECT - 15 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Please check the wire resistance. If necessary replace the cable set. 5 SEAT BELT TENSIONER SUPPLY WIRE RESISTANCE TOO HIGH - Please check the wire resistance. If necessary replace the cable set. 6 SEAT BELT TENSIONER SUPPLY WIRE - POWER SUPPLY DEFECT - Check the sensor wire for breaks or shorts. Check the connectors for corrosion and breakage. 7 CRASH SENSOR TRIGGERED - FRONT LEFT - Check the sensor, wires and connections for breaks, shorts or defects Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 8 CRASH SENSOR FAULT - FRONT LEFT - Check the sensor, wires and connections for breaks, shorts or defects Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. Replace the Crash Sensor if the fault recurs. 9 CRASH SENSOR GROUND CONTACT FAULT - FRONT LEFT - Check the sensor ground contact. Check the battery ground contacts. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. Replace the Crash Sensor if the fault recurs. 10 CRASH SENSOR TRIGGERED - FRONT RIGHT - Check the sensor, wires and connections for breaks, shorts or defects. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 11 CRASH SENSOR FAULT - FRONT RIGHT - Check the sensor, wires and connections for breaks, shorts or defects. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. Replace the Crash Sensor if the fault recurs. 12 CRASH SENSOR GROUND CONTACT FAULT - FRONT RIGHT - Check the sensor ground contact. Check the battery ground contacts. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. Replace the Crash Sensor if the fault recurs. 13 CRASH SENSOR SUPPLY RESISTANCE TOO HIGH - FRONT LEFT - Check the sensor, wires and connections for breaks, shorts or defects. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 14 CRASH SENSOR SUPPLY WIRE FAULT - FRONT LEFT - Check the sensor, wires and connections for breaks, shorts or defects Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 15 CRASH SENSOR SUPPLY RESISTANCE TOO HIGH - FRONT RIGHT - Check the sensor, wires and connections for breaks, shorts or defects. Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 16 CRASH SENSOR SUPPLY WIRE FAULT - FRONT LEFT - Check the sensor, wires and connections for breaks, shorts or defects Delete faults in memory, drive vehicle over 15 mph, then rerun diagnosis. 17 WARNING LAMP SHORT CIRCUIT - A short-circuit exists in the instrument panel or in the supple wire from the control unit to the instrument panel. Please check whether the SRS warning light either lights up permanently or not at all. 18 WARNING LAMP DEFECT - Please check the airbag signal bulb in the instrument panel and replace it if necessary. 19 CRASH DETECTION ACCUMULATOR ACTIVATED - The detection accumulator is activated by the operation of the SRS system. * ATTENTION! THIS ACCUMULATOR CAN ONLY BE DIAGNOSED AND RESET BY THE BMW DEALER. 20 SRS CONTROL UNIT DEFECT - DEALER REPLACEMENT ONLY -Delete fault stored in memory. Operate vehicle for 5 minutes. If the fault re-occurs, the SRS Control Unit will need replacement. 16 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 21 AIRBAG SUPPLY WIRE RESISTANCE TOO HIGH - PASSENGER SIDE - Please check the wire resistance. If necessary replace the cable set. 22 AIRBAG SUPPLY WIRE - DRIVER SIDE WIRE DEFECT - Please check the wire resistance. If necessary replace the cable set. SRS 2 (1991-93) CODE DESCRIPTION OF MALFUNCTION 1 FRONT SENSOR TRIGGERED - ONE TIME 2 FRONT SENSOR TRIGGERED - MULTIPLE TIMES 5 FRONT SENSOR TRIGGERED - PERMANENT 13 TWO FIRING CIRCUITS ARE SHORT CIRCUITED 19 FRONT SENSOR SUPPLY VOLTAGE - LEFT FAULT 20 FRONT SENSOR SUPPLY VOLTAGE - RIGHT FAULT 27 PRIMARY AIRBAG FIRING CIRCUIT IS SHORTED TO + BATTERY - Check wiring for short. 33 PRIMARY AIRBAG FIRING CIRCUIT IS SHORTED GROUND - Check wiring for shorts or breaks. 42 AIRBAG IGNITION CIRCUIT - DIVERS SIDE - Resistance too low 43 SEATBELT PRE-TENSIONING SYSTEM - PASSENGER AIRBAG - Resistance in circuit II is too low. 44 PASSENGER AIRBAG - Resistance in circuit III (or spare resistor) is too low. 45 AIRBAG IGNITION CIRCUIT - DIVERS SIDE - Resistance in supply wire is too high 46 SEATBELT PRE-TENSIONING SYSTEM - PASSENGER AIRBAG - Resistance in circuit II is too high. 47 PASSENGER AIRBAG - Resistance in circuit III (for spare resistance) is too high. 49 SRS WARNING LAMP FAULTY 50 SRS CONTROL UNIT DEFECT - DEALER REPLACEMENT ONLY -Delete fault stored in memory. Operate vehicle for 5 minutes. If the fault re-occurs, the SRS Control Unit will need replacement. 52 CRASH ACCUMULATOR TRIGGERED - DEALER REPLACEMENT ONLY 17 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm SRS 3 (1993-98) CODE DESCRIPTION OF MALFUNCTION 1 SRS CONTROL UNIT DEFECT - DEALER REPLACEMENT ONLY - Delete fault stored in memory. Operate vehicle for 5 minutes. If the fault recurs, the SRS Control Unit will need replacement. This code is also associated with low battery voltage. 2 AIRBAG IGNITION CIRCUIT - DRIVERS SIDE - DEFECTIVE 3 SEATBELT PRE-TENSIONING SYSTEM FIRING CIRCUIT - DRIVER SIDE 4 SEATBELT PRE-TENSIONING SYSTEM FIRING CIRCUIT - PASSENGER SIDE 5 AIRBAG IGNITION CIRCUIT - PASSENGER SIDE - DEFECTIVE 6-7 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 12-16 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 17 POWER SUPPLY - Check battery and charging system. 18 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 19 SRS WARNING LAMP FAULT 20 SEAT OCCUPANCY DETECTION CIRCUIT - PASSENGER SIDE 21 PRESSURE SENSOR - DRIVER SIDE 22 PRESSURE SENSOR - PASSENGER SIDE 23 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 24 SEAT BELT LOCK - DRIVER SIDE 25 SEAT BELT LOCK - PASSENGER SIDE 48-63 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 65 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.) 67-72 SRS CONTROL UNIT INTERNAL DEFECT (See fault code 76-77.). 73 TWO FIRING CIRCUITS ARE SHORT CIRCUITED 76-77 SRS CONTROL UNIT INTERNAL DEFECT - DEALER REPLACEMENT ONLY - Delete fault stored in memory. Operate vehicle for 5 minutes. If the fault re-occurs, the SRS Control Unit will need replacement. This code is also associated with low battery voltage. *** SPECIAL NOTE REGARDING SRS SYSTEMS ON *** E24 AND E30 CHASSIS (For use with Baum Tools CS1000, Carsoft Software or BMW MODIC.) On some E24 and E30 model BMWs, the RxD and TxD lines from the SRS control unit are not integrated into the 20 pin diagnostic socket found under the hood. In order to diagnose and reset SRS lights on these vehicles, you must tap directly into the harness coming from the SRS control unit. 18 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Diagnostic Tool Plug Pin SRS Control Unit Connector E24 models Pin #14 Battery (+) Battery (+) Terminal Pin #15 (RxD) Pin #6 (WT/YL) Pin #19 Ground Good Vehicle Ground Pin #20 (TxD) Pin #2 (WT/VI) E30 Pin #14 Battery (+) Battery (+) Terminal Pin #15 (RxD) Pin #6 (WT/YL) Pin #19 Ground Good Vehicle Ground Pin #20 (TxD) Pin #2 (WT/VI) E30 1992 Pin #14 Battery (+) Battery (+) Terminal Convertible Pin #15 (RxD) Pin #6 (WT/BLK) Pin #19 Ground Good Vehicle Ground Pin #20 (TxD) Pin #7 (WT/VI) 19 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm ELECTRONIC TRANSMISSION CODES 4HP22/4HP24 (EARLY MODEL THROUGH 10/89) - EGS 1.XX CODE DEFINITION OF FAULT EGS PIN OUT TRANS. CABLE (8 PIN) POSSIBLE CAUSES 01 Transmission relay Relay not switching 02 EPROM checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 03 Kickdown switch 2 Short to ground 04 Program switch 2 Break in wiring Short in wiring Defective switch 05 Throttle valve signal or accelerator pedal position - (EML pin 32) 7 9 Break in wiring Short in wiring Defective switch 06 Solenoid valve 1 16 5 Break in wiring Short in wiring Defective valve winding 07 Solenoid valve 2 17 6 Break in wiring Short in wiring Defective valve winding 08 Solenoid valves 1 & 2 16, 17 5, 6 Short in wiring Defective valve winding 09 Solenoid valve - Reverse lock 20 2 Break in wiring Short in wiring Defective valve winding 10 Solenoid valve 1 - Reverse lock 16, 20 5, 2 Short in wiring Defective valve winding 11 Solenoid valve 2 - Reverse lock 17, 20 6, 2 Short in wiring Defective valve winding 12 Solenoid valves 25 7 Short in wiring Defective valve winding 13 Solenoid valve - Converter lockup clutch 25 7 Break in wiring Short in wiring Defective valve winding 14 Solenoid valve 1 - Converter lockup clutch 16, 25 5, 7 Short in wiring Defective valve winding 15 Solenoid valve 2 - Converter lockup clutch 17, 25 6, 7 Short in wiring Defective valve winding 16 Solenoid valves - Converter lockup clutch 20 2 Short in wiring Defective valve winding 17 Reverse lock solenoid valve - Converter lockup clutch 20, 25 2, 7 Short in wiring Defective valve winding 19 Solenoid valve - MV2 17 6 Short in wiring Defective valve winding 20 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 18 Solenoid valve - Mv1 16 5 Short in wiring Defective valve winding 20 Power supply - MV's and Pressure regulators 1 8 Short in wiring Defective valve winding 21 Engine speed sensor signal 21 Engine speed too high > 6800 rpm 22 Pressure regulator 22 1 Break in wiring Short in wiring Defective valve winding 23 Ignition timing intervention 24 Break in wiring Short to ground 24 Speed sensor n-ab - Downshift prevention 8, 27 3, 4 Break or short in wiring from control unit pin 8 to speed sensor Engine speed sensor defective 25 Engine over-rev lock Engine speed exceeds output speed 26 KVA signal (ti) 11 Fuel consumption indicator (KVA signal) 27 Speed sensor n-ab Engine speed sensor or torque converter Stall speed exceeded 28 Breakdown display Transmission failure detected 29 Incorrect checksum in EGS program memory Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 30 Battery voltage Battery voltage too low >9 volts Check battery Check charging system 31 Shift lever position 28 200 Kickdown switch not working 201 Kickdown switch fault 202 Sport car transmission feature not selectable 203 Manual shift program feature not selectable 204 Program cannot be converted 6 205 No engine deceleration detected 24 206 False code set 207 No EML detected 300 Diagnostic circuit fault 301 Voltage to control No voltage to EGS control unit Check wiring harness 302 Shift lever position sensor Break in wiring Short in wiring Defective switch 303 Shift lever position sensor signal Break in wiring Short in wiring Defective switch 21 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 4HP22, 4HP24 (LATE MODEL 11/89 AND NEWER)- EGS 1.XX CODE DEFINITION OF FAULT EGS PIN OUT TRANS. CABLE (8 PIN) POSSIBLE CAUSES 01 Transmission relay Relay in EGS not switching 02 EPROM checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 03 Kickdown switch 2 Short to ground 04 Program switch E=pin 14, M=pin 15, S=pin 4 Break in wiring Short in wiring Defective switch 05 Throttle valve signal or accelerator pedal position - (EML pin 32) 7, 9 Break in wiring Short in wiring Defective switch 06 Solenoid valve 1 16 5 Break in wiring Short in wiring Defective valve winding 07 Solenoid valve 2 17 6 Break in wiring Short in wiring Defective valve winding 08 Solenoid valves 1 & 2 16, 17 5, 6 Short in wiring Defective valve winding 09 Solenoid valve -Park/neutral lock 20 2 Break in wiring Short in wiring Defective valve winding 10 Solenoid valve 1 - Park/neutral lock 16, 20 5, 2 Short in wiring Defective valve winding 11 Solenoid valve 2 - Park/neutral lock 17, 20 6, 2 Short in wiring Defective valve winding 12 Solenoid valves 25 7 Short in wiring Defective valve winding 13 Solenoid valve - Converter lockup clutch 25 7 Break in wiring Short in wiring Defective valve winding 14 Solenoid valve 1 - Converter lockup clutch 16, 25 5, 7 Short in wiring Defective valve winding 15 Solenoid valve 2 - Converter lockup clutch 17, 25 6, 7 Short in wiring Defective valve winding 16 Solenoid valves - Converter lockup clutch 20 2 Short in wiring Defective valve winding 17 Reverse lock solenoid valve - Converter lockup clutch 20, 25 2, 7 Short in wiring Defective valve winding 19 Solenoid valve - Magnetic valve 2 17 6 Short in wiring Defective valve winding 18 Solenoid valve - Magnetic valve 1 16 5 Short in wiring 22 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Defective valve winding 20 Power supply - Solenoid valves (MV's) and Pressure regulators 1 8 Break in wiring Short in wiring Defective valve winding 21 Engine speed sensor signal 21 Engine speed too high > 6800 rpm 22 Pressure regulator 22 1 Break in wiring Short in wiring Defective valve winding 23 Ignition timing intervention 24 Break in wiring Short to ground 24 Speed sensor n-ab - Downshift prevention 8, 27 3. 4 Break or short in wiring from control unit pin 8 to speed sensor Engine speed sensor defective Engine speed too high for intended gearshift 25 Engine over-rev lock Engine speed exceeds output speed 26 KVA signal (ti) 11 Fuel consumption indicator (KVA signal) 27 Speed sensor n-ab 8, 27 3, 4 Engine speed sensor Torque convertor Stall speed exceeded 28 Breakdown display Transmission failure detected 29 Incorrect checksum in EGS program memory Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 30 Battery voltage Low battery voltage Check battery and charging system 31 Shift lever position 28 Break in wiring Short in wiring Short in sensor 200 Kickdown switch not working 201 Kickdown switch fault 202 Sport car transmission feature not selectable 203 Manual shift program feature not selectable 204 Program cannot be converted 6 205 No engine deceleration detected 24 206 False code set 207 No EML detected 300 Diagnostic circuit fault 301 Voltage to control No voltage to EGS control unit Check wiring harness 302 Shift lever position sensor 303 Shift lever position sensor signal Break in wiring Short in wiring Defective switch 23 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 4HP24 - EGS 2.28 CODE DEFINITION OF FAULT EGS PIN OUT POSSIBLE CAUSES 01 Battery voltage + 1 Battery voltage too low >9 volts Check battery Check charging system 02 Output speed sensor (tr) 2, 28 Anomalous signal Not normal signal Signal not in allowable range 03 Engine speed signal 3 Break in wiring Short in wiring Engine speed too high >6800 rpm 05 Solenoid valve 1 5 Break in wiring Short in wiring Defective valve winding 06 Pressure actuator 6 Break in wiring Short in wiring (11) Wheel speed - rear left 11 Anomalous signal Not normal signal Signal not in allowable range (12) Wheel Speed - Rear Right 12 Anomalous signal Not normal signal Signal not in allowable range 13 Solenoid - Park/neutral Lock 13 Break in wiring Short in wiring Defective valve winding 14 Selector lever position L2 14 Vehicle accelerated while shift lever in park or neutral position Engine was started and the EGS control has not detected park or neutral position signal 19 Power Supply - Solenoid Valves and Eds's 19 Break in wiring Short in wiring Defective valve winding 21 Load signal (KVA signal) 21 Break in wiring Short in wiring 24 Solenoid valve 2 2 Break in wiring Short in wiring Defective valve winding 29 Shift Lever Position L3/l4 33, 39 Break in wiring Short in wiring (30) Wheel Speed - Front Right 30 Anomalous signal Not normal signal Signal not in allowable range 32 Engine Intervention 32 Break in wiring Short in wiring 39 Continuous Voltage + 39 Anomalous signal 24 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Not normal signal Signal not in allowable range 41 KD switch 41 Short to ground 42 Solenoid Valve - Converter Lockup Clutch 42 Break in wiring Short in wiring Defective valve winding 43 Program Selector Switch 43 Anomalous signal Break in wiring Short in wiring 47 Accelerator Pedal Position 47 Break in wiring Short in wiring (48) Wheel Speed - Front Left 48 Anomalous signal Not normal signal Signal not in allowable range 50 Shift Lever Position l1 50 Break in wiring Short in wiring 100 EPROM checksum Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 101 Incorrect Checksum in Program Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 102 Relay - EGS Control Unit Relay in EGS not switching in time 103 Wheel Speed Not Plausible Anomalous signal Not normal signal Signal not in allowable range 104 Stall Speed Monitoring Anomalous signal Not normal signal Signal not in allowable range 105 Wheel Speed - Lateral Slip Lateral slip for longer than 2.5 minutes Wheels out of alignment Suspension not level You've been racing on a circular track A4S 310R (THM-R1), A4S 270R (THM-R1) - EGS 4.XX CODE DEFINITION OF FAULT EGS PIN OUT POSSIBLE CAUSES 01 Solenoid Parking/neutral lock Break in wiring Short in wiring Defective valve winding 02 Program SWITCH E=pin 2, M=pin 31, S=pin 34 Break in wiring Short in wiring Defective switch 04 Engine Intervention 4 Break in wiring Short in wiring 09 KVA Signal (ti) 9 Break in wiring 25 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Short in wiring 11 Engine Speed Signal (n-mot) 11 Break in wiring Short in wiring 20 Transmission rotation speed signal (n-ab) - Stall speed signal 14, 20 No signal Anomalous engine speed signal 22 Transmission fluid temperature sensor 17, 22 Transmission temperature too high (>165c) 23 Shift Lever Position 26 Break in wiring Short in wiring Short in sensor 28 Battery Voltage + (Terminal 30) 28 Break in wiring Check battery contacts and wiring integrity 30 Kickdown Switch 30 Short to ground 35 Stop Light Switch 35 Break in wiring 37 Battery voltage + 37 Voltage out of range 38 Solenoid valve - Converter lockup clutch 38 Break in wiring Short in wiring Defective valve winding 39 Stop light switch 39 Break in wiring 40 Pressure regulator 40, 41 Break in wiring Short in wiring Defective valve winding 43 Solenoid valve 2 43 Break in wiring Short in wiring Defective valve winding 45 Solenoid valve - Band 45 Break in wiring Short in wiring Defective valve winding 48 Solenoid valve 1 48 Break in wiring Short in wiring Defective valve winding 54 Ground - Solenoid valves 54 Break in wiring Short in wiring Defective valve winding 55 Throttle valve signal (DKT) 55 Anomalous throttle valve signal Break in wiring Short in wiring 100 Speed monitoring Speed ratio n-ab/n-mot not correct for gear selected 101 Downshift lock Speed too high for downshift intended 102 Engine over-rev lock in 1st and 2nd gear Engine sped 300 rpm above output speed 103 EPROM error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 104 DKT engine temperature signal 35 105 DKT throttle valve signal 35 Break in wiring Short in wiring Anomalous signal 26 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 107 False code set 110 EGS control unit not programmed Have EGS control unit programmed 105 DKT throttle valve signal 35 Break in wiring short in wiring Anomalous throttle valve signal 106 MUX injection rate DDE sending faulty injection rate signal 110 EGS control unit not programmed Have EGS control unit programmed (150) Can timeout 1 Can signal not sent during engine start (ignition on) (151) Can timeout 2 Can signal not detected (engine running) (152) Can bus monitor Values in can ram storage not updated (153) Can status fault Control units with different can status' are installed on the same bus Replace with correct units (154) Can throttle valve signal Anomalous throttle valve signal detected by DME (155) Can load signal Anomalous load signal detected by DME (156) Can engine intervention DME cannot alter engine torque to match EGS signal DME does not match other can control units (157) Can engine temperature Anomalous engine temperature signal detected by DME (158) Can engine speed signal Anomalous engine speed signal detected by DME 200 Kickdown not working 201 Sport car transmission feature not selectable 202 Manual shift program feature not selectable 203 Program cannot be converted 6 204 No engine deceleration detected 24 205 Brake light Brake light test switch 206 False code set 300 Diagnostic circuit fault 301 EGS voltage supply No voltage to EGS control unit Check wiring harness A5S 310Z (5HP-18) - EGS 7.XX CODE DEFINITION OF FAULT EGS PIN OUT POSSIBLE CAUSES 02 Solenoid Parking/Neutral lock 2 Break in wiring Short in wiring Defective valve winding 03 Solenoid valve 5 Break in wiring Short in wiring Defective valve winding 27 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 04 Solenoid valve 6 - Convertor lockup clutch Break in wiring Short in wiring Defective valve winding 05 Pressure regulator Break in wiring Short in wiring Defective valve winding 08 Shift Lever Position L2 8 Vehicle accelerated while shift lever in park or neutral position Engine was started and the EGS control has not detected park or neutral position signal 09 Shift lever position L3/L4 37, 9 Break in wiring Short in wiring Short in sensor 12 Program selector switch 12, 13, 45 Short to ground 16 Turbocharger speed sensor 16, 44 No signal Anomalous engine speed signal 18 Kickdown switch 18 Short to ground Anomalous signal 19 ASC monitoring 19 Break in wiring Short in wiring EGS detected anomalous ASC signal ASC operation detected while shift lever in park or neutral 22 ATF sump temperature sensor 21, 22 Break in wiring Short in wiring 26 Battery voltage + 26 Break in wiring Check battery Check charging system 30 Solenoid valve 1 30 Break in wiring Short in wiring Defective valve winding 31 Solenoid valve 4 31 Break in wiring Short in wiring Defective valve winding 32 Solenoid valve 3 32 Break in wiring Short in wiring Defective valve winding 33 Solenoid valve 2 33 Break in wiring Short in wiring Defective valve winding 35 Throttle valve signal (dtk) 35 Break in wiring Short in wiring Anamolous throttle valve signal 36 Shift lever position l1 36 Break in wiring Short in wiring Short in sensor 40 Engine intervention 40 Break in wiring Short in wiring 41 Kva signal 41 Break in wiring 28 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Short in wiring 42 Transmission output rotation speed signal (n-ab) - Stall speed signal 14, 42 No signal Anomalous engine speed signal 43 Engine speed signal (n-mot) 43 No signal Anomalous engine speed signal 53 Power supply - Solenoid valves 53 Relay in egs not switching 54 Batter voltage + 54 Battery voltage too low (>9 volts) Check battery Check charging system 100 Speed monitoring Trans/engine speed ratio not correct for gear selected Speed sensor signal faulty Slip in transmission too high 101 EPROM checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 102 Program checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 103 Relay - EGS control unit Relay in EGS not switching in time 104 DKT- Temperature signal 35 Break in wiring short in wiring Anomalous engine temperature signal 105 DKT - Throttle valve signal 35 Break in wiring short in wiring Anomalous throttle valve signal 106 MUX injection rate DDE sending faulty injection rate signal 110 EGS control unit not programmed Have EGS control unit programmed (150) CAN timeout 1 CAN signal not sent during engine start (ignition on) (151) CAN timeout 2 CAN signal not detected (engine running) (152) CAN bus monitor Values in CAN ram storage not updated (153) CAN status fault Control units with different CAN status' are installed on the same bus Replace with correct units (154) CAN throttle valve signal Anomalous throttle valve signal detected by DME (155) CAN load signal Anomalous load signal detected by DME (156) CAN engine intervention DME cannot alter engine torque to match EGS signal DME does not match other CAN control units (157) CAN engine temperature Anomalous engine temperature signal detected by DME (158) CAN engine speed signal Anomalous engine speed signal detected by DME 200 Kickdown not working 201 Sport car transmission feature not selectable 202 Manual shift program feature not selectable 203 Program cannot be converted 6 29 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm 204 No engine deceleration detected 24 205 Brake light Brake light test switch 206 False code set 300 Diagnostic circuit fault 301 EGS voltage supply No voltage to EGS control unit Check wiring harness A5S 560Z (5HP-30) - EGS 9.XX CODE DEFINITION OF FAULT EGS PIN OUT POSSIBLE CAUSES 01 Pressure regulator - EDS 2 1 Anomalous signal Break in wiring Short in wiring 02 Solenoid Parking/Neutral Lock 2 Break in wiring Short in wiring Defective valve winding 04 Pressure regulator - EDS 4 4 Anomalous signal Break in wiring Short in wiring 05 Pressure regulator - EDS 1 5 Anomalous signal Break in wiring Short in wiring 08 Shift lever position L2 8 Vehicle accelerated while shift lever in park or neutral position Engine was started and the EGS control has not detected park or neutral position signal 09 Shift lever position L3/L4 37, 9 Break in wiring Short in wiring Short in sensor More than one program selector switch is applied to ground 12 Program selector switch 12, 13, 45 Short in wiring Short in sensor More than one program selector switch is applied to ground 16 Turbocharger speed sensor 16, 44 No signal Anomalous engine speed signal 18 Kickdown switch 18 Short to ground Anomalous signal (19) ASC monitoring 19 Break in wiring Short in wiring EGS detected anomalous ASC signal ASC operation detected while shift lever in park or neutral 22 ATF sump temperature sensor 21, 22 Break in wiring Short in wiring 26 Battery voltage + 26 Break in wiring Check battery 30 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Check charging system 29 Pressure regulator - EDS 3 29 Anomalous signal Break in wiring Short in wiring 30 Solenoid valve 1 30 Break in wiring Short in wiring Defective valve winding 31 Solenoid valve 4 31 Break in wiring Short in wiring Defective valve winding 32 Solenoid valve 3 32 Break in wiring Short in wiring Defective valve winding 33 Solenoid valve 2 33 Break in wiring Short in wiring Defective valve winding 35 Throttle valve signal (DKT) 35 Break in wiring Short in wiring Anomalous throttle valve signal 36 Shift lever position L1 36 Break in wiring Short in wiring Short in sensor 40 Engine intervention 40 Break in wiring Short in wiring 41 KVA signal 41 Break in wiring Short in wiring 42 Transmission rotation speed signal (n-ab) Stall speed signal 13, 42 No signal Anomalous engine speed signal 43 Engine speed signal (n-mot) 43 No signal Anomalous engine speed signal (51) Pressure regulator - EDS 3 51 Anomalous signal Break in wiring Short in wiring (52) Power supply - Solenoid valves or EDS' 52 Break in wiring Short in wiring 54 Batter voltage + 54 Battery voltage too low (>9 volts) Check battery Check charging system 100 Speed monitoring Trans/engine speed ratio not correct for gear selected Speed sensor signal faulty Slip in transmission too high 101 EPROM checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit Replace control unit 102 Program checksum error Damaged EPROM Program in memory faulty Reinitialize power to EGS control unit 31 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm Replace control unit 103 Relay - EGS control unit 52 Relay in EGS not switching in time 104 Engine over-rev lock Engine speed >6800 rpm detected 105 Speed monitoring Trans/engine speed ratio not correct for gear selected Speed sensor signal faulty Slip in transmission too high 106 Speed monitoring Trans/engine speed ratio not correct for gear selected Speed sensor signal faulty Slip in transmission too high (150) CAN timeout 1 CAN signal not sent during engine start (ignition on) (151) CAN timeout 2 CAN signal not detected (engine running) (152) CAN bus monitor Values in CAN ram storage not updated (153) CAN status fault Control units with different CAN status' are installed on the same bus Replace with correct units (154) CAN throttle valve signal Anomalous throttle valve signal detected by DME (155) CAN load signal Anomalous load signal detected by DME (156) CAN engine intervention DME cannot alter engine torque to match EGS signal DME does not match other CAN control units (e.g. ASC) (157) CAN engine temperature Anomalous engine temperature signal detected by DME Top Copyright - Baum Tools Unlimited Inc. Aug. 25, 1997 32 of 32 11/15/00 9:55 AM bmwcodes http://www.baumtools.com/bmwcodes.htm |
its a 2000 323i
