Old 09-28-2002, 03:09 AM
Project88HB Project88HB is offline
Angry Car Problems
Well i was just cruising blah blah in my stock std hatch , when all a sudden my car just started slowing down and my foot was full on the gas.... it slowed down to a stop.... i turned it off waitewd and tryed...battery not dead...but then again ti wouldnt die on me while i was driving if it was the battery...so then ithought MAYBE i flooded it i waited like 2 hours tryed again the same thing no start you hear th ebattery trying but no start.... so im asumming its the fuel pump... what do you guys think?... if it is im thinking about ordering one of these babys Walbro (255lph High Pressure) ... cause i plan on turboing my soon to be b16a1 powered hatch .... or do you guys think i should just get the 190lph.... anyhow you think its the fuel pump? how would i check... get back to me! bye bye
I believe that we should make the world a better place for our children, but not our childrens, children because children shouldnt be having sex...
Old 09-28-2002, 11:47 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well that happened to me before...the timing belt came off! Maybe its ur distributor.
Old 09-28-2002, 12:19 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
same here...and it was also the timing belt. there are a couple of things it could be. i wouldn't suggest just buying a new fuel pump until you're sure that's the problem.
check your distro. for sure!
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-28-2002, 12:27 PM
checked
i checked and all the belts are in tact.....
Old 09-28-2002, 12:32 PM
amy@af's Avatar
Re: checked
did you take the timing belt out? in my case it busted a tooth and we didn't find it until we took it out. and what about the distro? did you check that? check your ecu...it is very possible to get error codes without the check engine light flashing on....
Old 09-28-2002, 01:31 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
same thing EXACTLY happened to me ... i blew the hell outa my distrubutor. cost me just a bit over 400 for a new one, good quality so said my mechanic but i trust em, and half an hour labor to install.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 09-28-2002, 01:49 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
but did the samething happen to you guys. cause he said the he was driving and the car started slowing down even while he was giving it full gas, and it slowed to a stop.
first it cant be the timing belt coming off cause then the car would have just died, not slow to a stop.
all you guys saying distrubutor, but if the distrubutor went out, wouldnt the car just die, and not come slowly down to a stop ? even if the distributor was the problem, i would think the car would start to miss as it slows down.
dont get me wrong, i am not saying you guys are wrong. i just wanna know how the distributor can cause this, so i have a future reference in case this happen to me. i dont like to be told this part broke you gotta replace it, i wanna know what happen witht the part to cause it to break so i understand it better, and maybe prevent it in the future.
Old 09-28-2002, 05:09 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Dizzy breaks, or goes out = Zero to little spark.
Old 09-28-2002, 07:38 PM
where exactly would i look on the distributor? all the belts work... i had my friend try to start the car while i saw the belts turn and smelled some type of fume but no engine startup...
Old 09-28-2002, 08:14 PM
casedogg casedogg is offline
check the dipstick for water. if you headgasket is blown your oil will be real thin. mine did the same thing and it's the head gasket. that could be the fumes you smell. also you wouldn't be able to see if the timing belt was broke unless you took the valve cover off.
another thing is when the fuel pump relay gets old it can get bad. when it's real hot the "goo" inside expands and covers the contacts. you might want to try irt at night and it might just work. probably not though:smoka:
Old 09-28-2002, 08:55 PM
umm the oils not thin.... so i dunno whats up....
Old 09-29-2002, 01:29 PM
i think i found my problem, was checkin over eveyrthing today... was checking the spark plugs to see if they were bad... well i first pull of the last cap and Bam oil splurts out... im like ok... so i pull out the third... splat oil again... the second splat oil.... the first one had no oil... im like wow this is great my seals are bad.... so anyways i want to drain the oil, whats the best route to doing this you guys? i just wanna see if the reason my car slowed down to a stop was the oil and not the fuel pump.... thanks alot....
