Old 01-26-2007, 10:05 PM
KoDKingVegeta KoDKingVegeta is offline
1989 Honda Problem
Im sorry for post about this again. But when Im driving down the road, my car makes a sparking noise (sounds like some wires are sparking) then the car starts to sputer then it stalls. Then it takes me 10 - 15 mins to get it restarted. Iv replaced the fuel pump, the main fuel relay. And a few other odd relays. What can the problem be now?
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 01-26-2007, 10:36 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 1989 Honda Problem
I would have said Main Relay, but you say youve replaced it...or was it just the fuel pump relay?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-26-2007, 10:39 PM
Just the main fuel relay. I replaced the 2 other relays on the fuse holder.
*STOCK
The Cell Games
Old 01-26-2007, 10:59 PM
MishaA's Avatar
MishaA MishaA is offline
Yea, doesn't sound easy. Did you try to determine under what exactly circumstances it happens? And where sound comes from?
Old 01-26-2007, 11:03 PM
Its just random. And the nosie comes from the fuse area.
*STOCK
The Cell Games
Old 01-26-2007, 11:09 PM
FrodoGT's Avatar
Ok, so you didnt replace the main relay, its not attached to the fuse panel. Its on the left wall of the car just in front of the door hinge under the dash, hard to get to, but most common problem. And it will cause a sparking sound when it finally starts to go, from clicking on and off.
Current project:
Rio Red 91 hatch.
Old 01-26-2007, 11:57 PM
Ya you have to remove the hood poper to get to it. Iv already replaced that. It came out of the junk yard tho.
*STOCK
The Cell Games
Old 01-27-2007, 02:16 AM
FrodoGT's Avatar
Yeah..because I would trust a main relay from a junkyard..but if it still had the exact same symptoms before and after, you may be able to move onto another option. Or you just got another bad one.
Current project:
Rio Red 91 hatch.
Old 01-28-2007, 08:21 PM
Im Pay Pal ready, I really need one. My car keeps shutting off when Im driving it, and its taking longer and longer to restart. It shut off on my 2day and it took 10 mins to restart, Then I went to walmart and it took me 20 mins to restart. Then it shut off again on my way home, and it only took 5 mins to restart. But I need my car, its the only one I have, and right now I dont have the money the dealer wants for a new one.
Can sumone help me out.
*STOCK
The Cell Games
Old 01-28-2007, 11:47 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
When your car wont start check for spark. I'm willing to bet your problem is distributor related.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 01-28-2007, 11:51 PM
But every single time is has made that sparking noise, comin from under the dash near the fuse's. S Im thinking its fuse related. But Im just not sure. I'll try replacing the distributor.
*STOCK
The Cell Games
Old 01-29-2007, 11:15 AM
Do you hear 3 clicks coming from the main relay? Do this, turn the key to the "on" position, you should hear one click when the check engine light turns on. After about 3 seconds, when the CEL turns off you should hear another click. Finally, try starting the car with your foot OFF the clutch. Your car won't crank but you should hear a third clicking noise coming from the main relay. If you hear all 3, your relay should be good. If not, I'd say either re-solder your main relay, or pick up a new one. Also, don't just buy a new dizzy if you haven't gone and at least checked for spark first.
Old 01-29-2007, 12:09 PM
Thats the thing, I have checked for spark many times. And its getting spark every time.
*STOCK
The Cell Games
Old 01-29-2007, 04:14 PM
FrodoGT's Avatar
If you do have spark everytime, well theres only 3 things an engine needs to fire ..Fuel spark and air lol. Try cracking the nut on your fuel filter open and see if you are getting fuel to the engine.
Current project:
Rio Red 91 hatch.
Old 01-29-2007, 10:47 PM
Did that, and its getting fuel. I did it before I changed the pump, and it was getting little to none. After I changed the pump it got plenty.
*STOCK
The Cell Games
