Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-26-2007, 06:19 PM
CHenryJ CHenryJ is offline
Replacing windshield wiper motor 99 Crown Vic
Can anyone tell me how to replace the wiper motor on my 99 Crown Vic? My manual (Haynes) makes it sound easy by removing the linkage, removing the mounting bolts, disconnnecting the electrical connector and removing the motor. My question is does the bracket that the motor mounts to also have to be removed or does something else on the motor have to be removed. I don't have room to get my hands underneath to remove the motor from below. Any help will be greatly appreciated. By the way, I am having an intermittent operation problem and the blades do not assume the park position when they are turned off and I am assuming that the problem is in the park switch. Thanks.
Old 01-26-2007, 07:46 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Replacing windshield wiper motor 99 Crown Vic
You hve to remove the entire plastic piece the motor bolts too. It is fairly simple to do, you just have to find all the fasteners. There are a few clips that hold the 2 pieces together and there are about5 or 6 screws holding the plastic housing in place. The wiper is held to the plstic housing with 3 bolts. Just take your time and you should be OK.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-27-2007, 05:32 AM
Thanks so much for the reply. You verified what I suspected. I don't know about you, but at my age, it sure bothers my back leaning under the hood. Thanks again. Do you also think that the wiper motor is the source of the problem?
Old 01-27-2007, 03:10 PM
way2old's Avatar
TOKEN HILLBILLY
Usually if the wipers do not park in the park position, it is usually the motor. It donly tkes about an hour if you have never done one before. Not too bad a job. Just remeber to unhook and re-hook the washer hoses.
Old 01-27-2007, 06:43 PM
I'll try to get back on it and get the job done Monday. It has to be soon, because the safety inspection is due by the end of this month. I don't drive the car very much. There is only about 85000 miles on it and its a 99. Thanks again for the help.
Old 02-01-2007, 06:56 PM
I finally got around to replacing the wiper motor and things went pretty good. It took longer to remove the arms than the rest of the job. It seems that the clip on the driver side arm didn't want to disengage. Anyway, the motor was the problem and a rebuilt one from autozone cured it. Thanks for the info!
Old 02-01-2007, 07:09 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for the update. See ya
