Old 01-26-2007, 03:10 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
clutch question
hey..i got my 98 3000gt sohc..just had heads done.. im looking to get a clutch to really feel any gains cuz mine is gone..im wondering whats a good one to get..any links or spots to look..i looked on ebay at a few but im not sure if they fit sohc..are dohc and sohc the same?
Old 01-26-2007, 03:27 PM
2old 2old is offline
Re: clutch question
Is it slipping? Because unless you are using FI the stock clutch should be adequate.
Old 01-26-2007, 04:19 PM
Re: clutch question
ya like i said its gone..if im on it..from 1st to 2nd gear you can hear the clutch spinning for like 2 seconds before it grabs..i was just looking for a stock to a little above stock upgrade clutch is all...
Old 01-26-2007, 04:51 PM
Re: clutch question
For the money I would go stock...
I had a Spec Stage 2 (kevlar) and that barely lasted a year (it overheated in traffic) but the petal was heavier and really didn't do anything for me performance-wise (nevermind Kevlar seemed fickle... Judging from the net it seems to be a hit or miss).
The carbon-metallic sprung disks looks promising (I think it's Spec stage 3.5) but as I said, there just isn't the need for that much holding torque.
Old 01-26-2007, 08:11 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: clutch question
just go with another stock replacement clutch. it will hold the power fine. i do a lot of my parts shopping at www.thepartsbin.com. they have a good selection of OEM quality brands. also, they give you free shipping on orders of $50, and its fast shipping, too!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
