Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 01-26-2007, 02:28 PM
cristine cristine is offline
96 Dodge Stratus
I have a 96 Stratus ES and for the past 4 years or more the heat hasn't worked. Not even motor heat from the vents. My water pump was replaced in August 06. I was told it could be the thermostat. A different mechanic said the water pump wasn't working correctly so the thermostat couldn't be checked thoroughly. My car hasn't run hot since the water pump was replaced and I've taken the radiator cap off to see the water boil and flow which leads me to believe the pump works. I purchased a Haynes Repair Manual to help me understand the coolant flow and I realized the overflow tank plays a major part. I lost the overflow tank cap long ago and used foil and electrical tape to cover it for the time being. I think I had warm air this morning. Could this be so????
Old 01-26-2007, 07:12 PM
KimMG KimMG is offline
AF - Advisor
Re: 96 Dodge Stratus
Is coolant circulating through the heater core?
Is the blend door opening?
Old 11-17-2007, 10:59 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
if it was the thermostat stuck shut then the engine would be super hot and radiator wouldnt be
if it was stuck open it would take a really long time to warm up the engine
but all hoses would be at least real warm
and the radiator too
im working on a 99 breeze right now that i was told needed the heater core replaced but i am not so sure now after looking everything over on it this mornign
the lower rad hose is cold, the temp guage is 160, the upper hose and engine are hot, and so are both heater core hoses, and the HVAC panel assembly is working properly and changing vents/defrost locations great
i am putting a new thermostat in it right now,
and if that doesnt do it then im going to reverse the core hoses
and run some new fluid since it is dirty dark green old looking
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
