Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 01-26-2007, 12:13 PM
beeyond beeyond is offline
No Spark/No Fuel Tried Everything
Hey if someone can figure this one out it'll be cool...
no spark and no fuel....
checked PIN 54 on ECU -- yes there is power
bought fuel/ign relay -- #3 relay
used another ecu -- a friend had one laying around.. only thing is it came out of an auctioned car...so we never heard the car run. however, i doubt this to be the ecu itself..
what do you guys think??? so confused.........
Old 01-29-2007, 04:51 PM
Re: No Spark/No Fuel Tried Everything
dang where is boschman..... seems like he may be the only guy to help...
Old 01-29-2007, 07:01 PM
mouse ate a power line possibly....hehe!!! hmmm maybe corrodded power supply lines.... fuel pump and sparks are all dead....
Old 02-02-2007, 01:24 PM
Doug Tatham Doug Tatham is offline
What year? Check threads on alarm systems. Maybe cut off because alarm needs to be reset. Check fuses, the aluminum corrodes and you lose good contact. Many a jetta has been towed for this reason.
Old 02-11-2007, 06:40 PM
matthew_magic matthew_magic is offline
im having the same problem i actally got the car to push start
Old 02-13-2007, 03:14 PM
You may try hot wiring it. With the key in the on position run a wire from the + terminal to the solenoid where your ignition connects. You'll bypass most ignition issues. If it works, you'll have eliminated a lot of possibilities.
