Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-26-2007, 11:47 AM
Coldspark Coldspark is offline
97 Malibu - Bad compressor, bearing grinding
Was wondering if anyone who knows more about cars/malibus than I do could answer a question for me. I have a 2.4 97 malibu that was making a metalic grinding noise that was progressively getting louder. I brought it into the shop and aparantly it is due to the fact that a bearing in the compressor is going bad because it is not getting lubricated due to the fact that the compressor itself is bad. Ive known for a while that the compressor was bad, but didnt think too much of it because I had thought that the only effect that would have is that my A/C wouldnt work. Is there a way to disengage the compressor from the belt so that I do not have to replace the A/C in my car? Any input on this would be really appreciated.
Thanks
Old 01-26-2007, 02:52 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Bad compressor, bearing grinding
Regretfully, you have a car that you can't just eliminate the A/C compressor and use a shorter belt due to the way the belt routes. Dorman makes A/C compressor bypass pulley assemblies for many vehicles, but your car/engine combo isn't one of them. Your only option is to repair or replace your compressor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-27-2007, 10:58 AM
slls slls is offline
Re: 97 Malibu - Bad compressor, bearing grinding
Thanks
You just need a new clutch bearing, any good A/C shop will do the job. If they tell you you need a new clutch try another shop, the bearing is replaceable.
Old 01-28-2007, 03:35 AM
SPRaYeD9 SPRaYeD9 is offline
Banned
you could try taking the compressor off and tying the belt in a knot to make it shorter
