Antifreeze question
I have a 1994 Lumina witha 3.1L engine. I recently changed the thermostat and the upper radiator hose. Since then i have noticed that the antifreeze in the radiator don't get hot but the hose that I changed is hot.
Is there blockage somewhere? Thanks in advance for any help. |
Re: Antifreeze question
If you didn't bleed the air out of the cooling system after changing the t-stat, it's possible that there is air trapped in the engine which isn't allowing proper coolant circulation.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
I had the same problem . there was a bleeder valve that I had to open to let the air out ...
Ditto. You're airlocked. Open the bleeders and fill w/engine off, run to operating temp, let cool for 15 minutes or so, open bleeders and fill, repeat until you get no air when you open them.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
