Old 01-25-2007, 08:25 PM
toberlin1116 toberlin1116 is offline
2000 Honda Accord heater problem
My 2000 Honda Accord will not heat to it's full potential. The temperature gauge doesn't reach the middle of the meter. I had the thermostat changed and flushed the radiator. Does anyone have any ideas for what the problem might be?
Old 01-26-2007, 12:46 PM
somick's Avatar
somick somick is offline
Re: 2000 Honda Accord heater problem
On my 99 Accord LX my gauge goes up to only a quarter of it.
At first I thought that I had problems. Replaced thermostat, measured engine temperature. Everything stayed the same.
I think this is just a gauge. It is not suppose to be that accurate. It just gives you a hint that the car has warmed up.
What gives you idea that your car is not warming up?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 01-26-2007, 12:48 PM
somick's Avatar
Is your car's cooling fan comes on when you stoped with engine running?
Old 01-26-2007, 05:25 PM
Sam
The interior of the car isn't getting enough heat. I get some heat through the heater vents but not warm enough. Also, why is the thermostat's max temperature only 172 degrees, instead of most cars 195 degrees?
Old 01-26-2007, 09:37 PM
somick's Avatar
Well, you might picked a wrong thermostat.
Another reason might be air in the system.
Sam
Old 01-27-2007, 09:36 PM
Glen_T Glen_T is offline
Have you ever replaced the cabin air filters? Perhaps they are plugged and you are not getting much air flow, so you don't feel much heat.
Another potential problem would be the valve that allows coolant flow into the heater core in the dash. The valve is located near the firewall on the passenger's side on one of the coolant hoses leading to the heater core. If You could disconnect the cable to it and see if it turns freely.
As far as the thermostat temperature, my manual says that it should start to open at about 176F and is fully open at 194F.
Hope this helps...Glen
