Old 01-25-2007, 04:50 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Motor Mounts
My lower engine mount needs to be replaced but first I need to fix the mount spot. The bolt on the rear side has stripped out the threads in the frame. Should I weld the new mount in place or should I tap out the hole and put a new bolt there?
AF COMMUNITY GUIDELINES
Old 01-25-2007, 05:30 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Motor Mounts
I'd rethread the hole and put a new bolt in there. Since you're going to do a swap in it eventually anyways, it would just be a clearance issue (if it was welded in) when you try to get the motor and tranny in.
Old 11-03-2010, 07:16 PM
Kevins1955 Kevins1955 is offline
Love cars
Question Re: Motor Mounts
Hi,
I have a 96 Civic that needs a new lower mount on the drivers size. The replacement part I got from Autozone has a very loose fit from the center mount bushing to the shaft from the motor. Is that normal? I don't remember the original being loose on the shaft.
Thanks,
Kevin
