Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2007, 02:42 PM
nmn54 nmn54 is offline
98 Firebird close to overheating
First, it's a V6 98 Firebird with over 100,000 miles on it. I've recently had my coolant changed and flushed the radiator, but did not replace the thermostat.
The car usually runs with the guage sitting around 180 the entire time I drive it. Now, it will start off below and by the time I get to school it will be 3/4 to the red zone to overheating, the drive to school is not that far probably a mile or so. Yesterday, the guage would get up real high and then randomely fall down to 180 and go up again. It's been doing this for about a week, and it was doing this for about a week before I had my coolant changed and radiator flushed. After I did that it stopped for awhile until now.
So, do I need to replace the thermostat and refill the coolant? Or is there something else I should do if you've had the same experiences?
Also, I'm not that knowledgeable about cars so if I said something wrong and everything let me know and I'll try to re-explain it.
Old 01-25-2007, 04:26 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 98 Firebird close to overheating
Originally Posted by nmn54
So, do I need to replace the thermostat and refill the coolant? .
Cheap way to start off
also, make sure to replace the radiator cap as well.
Other things:
check the radaitor fins for blockage from leaves or other trash and belt tension.
Old 01-25-2007, 06:23 PM
Alright, thanks. Will do that this weekend.
Why do I need to replace the radiator cap? Cause my friend did that, I'm just wondering, not questioning.
Old 01-25-2007, 06:44 PM
Bassasasin Bassasasin is offline
Ive seen the thermostats get crystals on them and such..
Kindof mucky stuff too..
Its a great idea to swap it out and most likely the problem.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 01-26-2007, 12:12 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
also... check that your electric fans are kickin in.. the temp stay down if your car is moving but it'll spike if your cars standing still and your fans arent on..
remember the coolant temp sensor might be broken too.. they might be telling you its okay and stuff when its not or vice versa. cheap ~10$ fix for that..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 01-26-2007, 12:47 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Fans are programmed to kick in at 216 degrees on the V6, I'd make sure they kick on....turn your A/C on and make sure the fans even work.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-26-2007, 10:18 AM
wrightz28's Avatar
It's a rule of thumb. The cap maintains system pressure on the system. The more pressure, the higher the boiling point, hence how a engine can run 220* without blowing up.
Old 01-26-2007, 06:42 PM
Naw, I hear the fans running when I shut off my car sometimes so I know that they're working, or at least attempting to.
I'll put in a new thermostat and cap tomorrow sometime, thanks for all the help.
Old 01-28-2007, 03:56 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
yea check that thermostat
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
