Old 01-25-2007, 02:26 AM
naif0391 naif0391 is offline
lights coming on randomly/ bad sensor?
hey everyone i have a 97 gt and lately after about 10 minutes of driving, my abs light, trac off light and check tire pressure light all come on... anyone know what this is?? thanks
Old 01-25-2007, 07:59 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: lights coming on randomly/ bad sensor?
Common issue, bad wheel sensor. Since the bearing and the sensor are one unit the bearing will also need to be replaced. Once the bearing and sensor are replaced the issue should go away.
Old 01-25-2007, 08:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Lynn (GTP Dad). You can jack the car up and see if one wheel has a lot of free play, which would identify the offending hub. You could also use a multimeter and check the resistance in the connector (it should be approx 1k ohms) if there is no free play. If neither of these tests fingers the bad hub, you may have to have it scanned with an ABS capable scan tool (the free scans at A-Z and Advance are not ABS capable).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-26-2007, 02:52 AM
cool, thanks guys
