Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-27-2002, 04:04 PM
DelSolSI-96 DelSolSI-96 is offline
Send a message via AIM to DelSolSI-96
Will it Blow?
I was just woundering about any NOS that would give me a quick spark of power with out any major damage. I have a pretty much stock 96 del sol si. Not shure the motor code. Who has a nice setup for not to much money. I just want something to playwith doesn't have to do crazy things. Any information would help thanx
Got Sol?
Old 10-01-2002, 01:30 PM
FREED0MFiST FREED0MFiST is offline
Send a message via AIM to FREED0MFiST
I hear the rule that your engine can handle a shot of nos equal to 40% of your current engine horsepower. Zex makes a pretty cheap kit.
Old 10-05-2002, 10:47 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Im running the 75 horse short on my zex kit, on my D16Z6 motor with no problem yet...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-15-2002, 06:05 PM
79_MonteCarlo 79_MonteCarlo is offline
If I were you I wouldn't get NOS unless you're prepared for the possible consequences. This kid I know put a 65 shot on a relatively stock civic Hatchback. The first time he sprayed he melted his spark plugs, The second time (2 days ago) he threw a piston through the block. I don't know how it happened but I just saw the aftermath, which may I add was quite comical
Old 10-16-2002, 01:05 PM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
Nitrous is safe. It all comes down to tuning. As long as you have a proper fuel setup you can easily run a 75 shot with ease, as long as your motor is already in good running condition. People that fry their motors are the people that don't take all the steps, that goes with any form of forced induction that you do. Talking to a local shop that has done setups before is always the safest thing to do.
00 civic with bolt-ons, i swear
Old 10-16-2002, 05:46 PM
How long does it take for a nitrous install? Like how long would it take to get it put in. How much to fill up the bottle also? and finally, would it be stupid to run nos with stock exaust?
Old 10-17-2002, 07:24 AM
it depends on the kit, but the average install i believe should take about 4 hours to do if you have all the proper tools. I've seen some shops only charge 20 dollars to fill the 10lb bottle. No, a stock exhaust would be fine, but a 2 1/2in would be better.
Old 10-17-2002, 10:49 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Install time depends on what all you're installing...More components and accessories you're adding, more time you're adding. It took me about 12 hours to do my previous n2o install...Bottle refill depends on the station...The place I went to was 3.37 per pound...so about $35 for a full fill. You can run nitrous with the stock manifold and exhaust, but you'll see a bigger gain with an aftermarket exhaust system.
There's no replacement for displacement...No, not even a turbo.
Old 10-17-2002, 12:01 PM
I noticed the zex kit says you can sit with the system armed, and once you hit full throttle itll go. So that means when i race ill be spraying through 1st, 2nd, 3rd, and fourth gear? It the NOS kit like that?
Old 10-19-2002, 10:06 PM
gunnmen01's Avatar
I have the zex kit, i spray at high rpm in 1st gear and ALL the way 2,3and 4th, all the way thru the 1/4 mile. Ran 15.4 at the track 3 weeks ago.
gunnmen01
This will blow your mind!...... nuthead54 Car Videos 0 09-08-2007 07:09 AM
2007 Nissan Sentra will blow you away - Pacifica Tribune Automotive News Automotive News Desk 0 12-14-2006 02:50 PM
The Hi"s And The Mid"s Will Blow You Away TRACYCULBERSON Car Audio 20 09-20-2005 02:40 PM
**** Ac Unit Only Turns On When Hot Wired ** It Will Blow Cold fazd Engineering/ Technical 1 06-18-2005 11:59 AM
No air or heat will blow out ridgemer Lumina 12 05-21-2005 11:23 AM
