speedometer not working
Ok so I still have a lot of electrical things on my car not working.. are there any wires that go to the back half of the car for the speedometer?? i also cant get the fuel guage to work!! I thought i had all the wires for the guage connected.. but i guess not.. anyways good ideas on how to test and work out untill i find why the speedometer is not working?
Re: speedometer not working
^The speedometer is gear driven, there will be a black cable coming out of the firewall that will come down into the engine compartment, on the front differential, you will see a place where that connects to the transmission... you can unscrew that cable and unbolt the sensor (1-10mm bolt, IIRC)... check to make sure that sensor isn't all chewed up, if it is, replace it... if not, you'll have to replace the cable or the speedometer assembly... I'm not for certain on the fuel gauge, but it is an electrical sensor, that you should be able to trace down the wires...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
here's some more info on the speedo gear and its location. its basically directly above the differential in the transmission.
http://stealth316.com/2-speedgear.htm
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
well i went in there to find out why my speedo isnt working..and look at this
![]() looks like the speedo cable got fried from the sensor? not sure what to do or what i need (speedo sensor, cable, gear?)
Pics Last edited by dhrubio; 07-05-2007 at 05:39 PM. |
All TT's and 94+ NA have speed sensros.
dhrubio---> so somehow the wires to your speed sensor got cut or torn? i would definitely repair the broken wires. not sure how much wire is left on the sensor side, but i would repair it first before buying a new sensor.
From the pic it actually looks to me like the plug in pulled apart. It may be fixable
connector
![]() heres the bottom of the connector ![]() and heres my problem: the top; you can see the three holes where the three wires should be ![]() a couple posts up i put a picture of the whole area and you can see the 3 wires just hanging around
Pics |
