Old 01-24-2007, 09:16 PM
fastcivic90 fastcivic90 is offline
Send a message via Yahoo to fastcivic90
Air ratio install
Hello guys I am trying to install and air fuel ratio gage on my 3000 Gt
any one knows the color code for this cables Tanks .
Old 01-25-2007, 02:18 PM
Igovert500's Avatar
blue + red light magnet
Re: Air ratio install
Is it a wideband or did you just get a narrowband? What wires do you need?
Going by wire colors is a sure way to ruin electronics. Go to stealth316.com, look at the ecu pinouts and then you can kinda use this as a guide if it is a narrowband.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-25-2007, 08:07 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Narrowband FTL. I put one in my Talon and its useless. It just bounces around and doesnt tell me shit. I am getting a wideband in the next few weeks.
Old 01-26-2007, 10:06 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I agree... the narrowbands have no accuracy to them and they are too slow to show you what's going on...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-26-2007, 11:51 AM
Stealthee's Avatar
It looks pretty though.
Old 01-29-2007, 06:00 PM
dude I have not a clue on this wide or narrow ban i only nee the color code but tanks for ur help
Old 01-29-2007, 06:42 PM
Stealthee's Avatar
Narrow band reads off the stock o2 sensor. Wideband uses an aftermarket o2 sensor and gives you a much more accurate reading, enough to tell you the exact air fuel ratio you are running. The narrow band gauge is just "guessing"
Old 01-30-2007, 11:13 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I'm not even sure that guessing is accurate. More like its a gauge that blinks colored lights at you.
Narrowband(stock) O2 sensors have 1 purpose, gas mileage when cruising. They do nothing else. Hooking a gauge up to them in an attempt to see A/F ratio is a waist of time, and I consider it counter productive.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-30-2007, 02:22 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i am actually looking to maximize my fuel economy when cruising. but i need to understand a little more. i have a book i need to re-read about ECUs and stuff. i bought an HKS S-AFR with the hopes of leaning out the fuel mixture around the 2k-3k rpm range, so i could get better gas mileage when cruising. however, what happens if i decide to go WOT? should i only go WOT after 3k rpm? i don't think my S-AFR can tune based on throttle position, but i'll have to go back and look.
any info would be helpful. perhaps i should start a new thread.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-30-2007, 03:11 PM
Mikelb's Avatar
What we're getting at is, you can't tune with a narrowband (standard O2)... you have to buy a wideband, or else the tune would be way off (standard/narrowband are too slow and not accurate) and you could blow your motor...
Best idea is to buy a wideband kit, PERIOD....
Old 01-30-2007, 03:28 PM
Narrowband tells the ECU if you are above or below 14.7:1. You can change your tune, and the computer will just correct it back to how its supposed to be, up to a certain point. If you keep leaning it out past what the computer can correct you will do damage to your motor.
When you go WOT the computer stops reading the o2 sensors and just reads the fuel map. A certain amount of airflow = a certain amount of fuel. This is where you can tune things because you are changing the airflow signal that the computer is receiving.
Old 01-30-2007, 06:51 PM
Linebckr49's Avatar
makes perfect sense. the wikipedia article on oxygen sensors has some good info as well.
i'm gonna go back and read some more of this book i have called How to Tune and Modify Engine Management Systems by Jeff Hartman.
93 3000GT base
