Old 01-24-2007, 04:44 PM
sinfull90 sinfull90 is offline
Send a message via MSN to sinfull90
6.0l rough idle/almost stall
so i was driving around town and my truck started to die, but didn't quite. i have a fuel pressure gauge and it's running at 58-60 psi, and no drop in fuel pressure when the accelerator was depressed. i opened up my air box and hear this strange wheezing sound... like air restriction. give her a shot on the throttle and it clears up, wait 30 sec. and it's back. idle is about 300 rpm or so but i believe this is caused by the restriction of air flow. the first time it happened i pulled the top of the air box off and it sounded like a bent push rod, wheezing in and out, shut the truck off and fire it back up and it goes away, no codes or anything. i'll try the TB cleaning but as far as the IAC Valve, i don't have one seeing as it's all TBW (i think looking for some direction.
thanx
lee
2000 Silverado 1500 SB Reg. Cab 4X4
6.0l LQ9 (was 4.3L) w/ stand-alone harness
Electric Fans w/ stand alone B&M trany cooler
Volant Intake
OBX Long Tube Headers w/ Magnaflow 2.5" True Duels
Heavy duty leaf pack in back
4X Rancho RS9000X
Otto-R racing seats
Stainless instrument panel backing
Custom painted red interior
4X 6.5" Light Force lights
31" Wrangler MT/R
Interior roll cage coming soon!
Old 01-24-2007, 06:47 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: 6.0l rough idle/almost stall
Yea, your truck should be idling at around 500-700rpm, definately not 300. I would have first suggest the fuel pressure regulator and fuel pump, that was the issue my truck had with almost the same symptoms you described.
Not sure about the wheezing, and I hope you figure it out. Let us know.
*Under Construction - New sig to debut*
Old 01-24-2007, 07:09 PM
so after a few quick checks i also noticed a weird smell... kinda smells like fuel but not really, more naptha gas kinda smell, i run high test all the time in my truck and shouldn't be having any "bad fuel" issues, just filled up my tank yesterday. fuel pressure regulator is an AEM, so it should be working fine. fuel pressure is steady @ 58-60 psi, throughout 500 RPM to 4500 RPM. it seems to run fine until i put my foot in it and then it seems to start doing it's thing. now for some issues: the exhaust isn't "tight" as i scabbed together the bits and pieces of the exhaust from the 4.3l. could this cause some "back pressure" problems? i've pretty much built this truck so i know there are no fuel line pinches as it's mostly new bent SS tubing. the motor has 15000 KM on it, oil is great, coolant is fine, all the normal stuff is good. one last thing, what exactly is this "carb cleaner" ppl say to use to clean out the throttle body? should i be looking for something specific? thanx again for looking at my ramblings.
lee
Volant Intake
4X Rancho RS9000X
Otto-R racing seats
31" Wrangler MT/R
Old 01-25-2007, 02:08 PM
wrparks wrparks is offline
any auto shop should have a can of carb cleaner. Says on the label "carb cleaner" (though admittedly they probably spell the whole word) or possibly even throttle body cleaner if your lucky. It's just a solvent to clean up carbon and other gunk. Personally, I don't know if one brand is better than another, just stick to a brand you've heard of and it should be fine. That could be your problem, but if so it's seriously dirty. Just to state the obvious, but is your air filter dirty?
Old 01-26-2007, 07:58 PM
air filter is clean, it does the same thing if the filter is off. i'll have to wait a few days to get the carb cleaner as i am in camp at work... thanx for the input.
lee
Volant Intake
4X Rancho RS9000X
Otto-R racing seats
31" Wrangler MT/R
