Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 01-24-2007, 03:03 PM
ashers ashers is offline
Question car dummy needs help with ignition
i bought a new ignition core for my 91 carolla nd have no idea how to install it. i know very little about cars and everything i read seems over my head. if anyone can provide mw with simple step by step instructions i would greatly appreciate it!! i need my car working by tonight!!!
Old 01-24-2007, 06:43 PM
KimMG KimMG is offline
AF - Advisor
Re: car dummy needs help with ignition
You may not need a new tumbler. You or a locksmith maybe able you remove the broken piece.
Can you turn the tumbler?
http://www.autozone.com/servlet/UiBr...3d8016becf.jsp
If not, you may have to remove the steering lock and take to a locksmith.
There are usually two bolts with sheared off heads that hold the steering lock assembly to the column. Some have used easy outs to remove the bolts, others have used a dremel with a cutting wheel to make a slot and then use a standard screwdriver to remove, and some have had luck using hammer and a punch. To use the punch, place tip of the punch close to the edge and tap the bolt in a counter-clockwise direction.
