Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-24-2007, 02:55 PM
Joeray007's Avatar
Joeray007 Joeray007 is offline
Stereo Installation
Hello all,
Does anyone knows how to install a aftermarket stereo? I already installed the stereo in my 84 caprice, but I don't have any memory. Evertime I shut the car off adn restart it, I lose all my settings.
Thanks.
Old 01-24-2007, 06:33 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Stereo Installation
Originally Posted by Joeray007
Hello all,
Thanks.
Your stereo should have two power connectors - one yellow and one red. Usually, the red one is power and the yellow one is memory - could be the other way around as well ... check your manual. The one that says "BAT" needs to be connected to a battery terminal on the fuseblock - a connector that has power on it no matter what the switch position. If you have this lead connected to an ignition switch source (no power when switched off), you will encounter the behavior your deck is exhibiting.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-26-2007, 04:16 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
You can get adapter harnesses that make installation easy. Just solder the leads from the adapter to the leads from the deck harness, then plug the factory harness into the adapter harness and everything should work as intended. You can also get adapter kits to fit the single DIN deck into the one and a half or double DIN opening in your dash, so everything looks clean and tidy.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 01-26-2007, 07:19 PM
kahjdh's Avatar
kahjdh kahjdh is offline
I did this on a 84 monte and a 87 s10, you need to hook up the constant to the orange wire from the original sterio. If it is gone(cut, missing) you can splice into the cigarette light wire or run a new one.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
