Old 01-24-2007, 02:04 PM
fantastic's Avatar
fantastic fantastic is offline
'00 Lug Nut Torque
Can anyone tell me what or where to find the touque amount on the lug nuts? My wifes car vibrates when brakeing and I read in another post that this can cause warping of the rotors? I am not sure if this is true but the brakes were replaced (rotors and pads) about 3 months ago and all tires were balenced.
Any info would be a big help.
Thanks
Old 01-24-2007, 02:12 PM
maxwedge maxwedge is offline
A990 racer
Re: '00 Lug Nut Torque
100 lb/ft torque. Sounds like the rotors are warped though.
Old 01-24-2007, 02:19 PM
fantastic's Avatar
That was fast. Would it matter if I had the rotors turned or once there warped there warped?
Old 01-24-2007, 04:07 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
IF there's enough material left where they can turn out the warpage, you can reuse them, but there normally isn't. Even brand new rotors with very few miles are too thin to turn back smooth once their warped.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-24-2007, 05:31 PM
1typhoon 1typhoon is offline
Banned
Presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of pro/DIY experience I have never seen a warped brake disc.
I have seen lots of cracked discs, and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not.
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
Old 04-26-2007, 11:57 PM
alfieferenzo84 alfieferenzo84 is offline
100 ft , have them checked to specs and see if they can be resurfaced if not just buy some better ones my mom goes thou rotors every yr on her grand prix
