Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-24-2007, 10:57 AM
NyScOoBy1 NyScOoBy1 is offline
Abs Light Is On ...
How do i turn off my abs light?? im not very good with cars .. all i kno it has something to do with antilock brakes. but wat do i do?
Old 01-24-2007, 01:31 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Abs Light Is On ...
If the abs light is on you need to go to autozone and have them scan the computer for trouble codes. They scan for free, mechanic shops and dealerships charge an arm and a leg. But you chan check your brake fluid before you go to make sure its not low. I have seen the pulse ring break a few teeth off and set off the abs light. The anti-lock brake system has a lot of small parts that make it work. There could be a problem with any number of them. Have the codes scanned to help narrow down the search.
1969 Cougar
357w & TKO - 475hp
