Old 01-24-2007, 03:37 AM
[email protected] gpleach@iprimus.co is offline
VS series 3 stopping
I have a v6 vs and it sometimes stalls when going up hills. It just stops without warning and starts again after about 5 mins..It has only done this on inclines..It can go for days or weeks even months before it does again... Any idears...TELL ME PLEASE !!!!!It's driving me looney...
Old 01-25-2007, 12:37 PM
UncleBob UncleBob is offline
AF -Advisor
Re: VS series 3 stopping
Well, at least we know its a V6. How about some more info
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-25-2007, 01:59 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
He has an Ausie IP adress, so it must be a VS Holdon Commonwhore.
Uses the good old buick 3.8 V6
Old 01-25-2007, 09:30 PM
It's a VS 1999 ,series 3...Auto...Yes it's Australian...3.8 and of course a ute....Done about 200,000 km...
Old 01-25-2007, 10:59 PM
Moppie's Avatar
Master Connector
So it's only just been run in then?
Old 01-26-2007, 04:39 PM
Yes .....Only driven to church on sunday's......
Stops every other day..............
Old 01-26-2007, 05:55 PM
gouldie1903 gouldie1903 is offline
low fuel pressure possibly?
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 01-26-2007, 06:53 PM
Moppie's Avatar
Master Connector
How well services is it?
I wonder if its something silly like the gear box over heating, throwing a code, and shutting the car down?
Old 01-26-2007, 09:10 PM
Yes somebody said that to me allready .I'll get the mechanic to look at that when I get it serviced next... My mate said as I go up hill the fuel rushes back over the pump and may cause it to flood or stop pumping . Though It never splutters and stops..It just stops instantly..As you are the second person to mention that to me I might just change the pump at the tank and see how it goes...I will let you know how it turns out....THANKS...
Old 01-26-2007, 09:27 PM
Serviced regularly..I got the gear box serviced last service..## THOUGH Last time it stopped the gearbox light came on ...on the dash....This has only come on once and it has stopped about 15 times...The hills It stops on are just normal inclines, not mountains....so to speak...I guess I'll find out when the mechanic hooks up the computer...I Will let you know..Regards Gavin...
Old 02-13-2007, 07:54 PM
Thanks to you people who put in your 2 cents and giving me some idears to work with....I took the car to the shop and got him to check what the computer had to say about things and it came up with crank sensor....He has changed this so I hope it solves the problem of stopping all the time....It was getting worse in the last month....If it does not fix the problem I'll let you know.....Thanks again for your time fellers.......Regards Gavin....
