Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 01-23-2007, 09:45 PM
clairabell clairabell is offline
Unhappy Service vehicle ,abs, and trac off lights
Tonight the sevice vehicle soon light, trac off and abs all came on. My husband suggested it is a ground wire that's off. According to what I read from other postings this isn't correct. What could it be?
I have alot of driving tomorrow.
BTW the vehicle is a 2002 Cavalier.
Thank You.
Old 01-24-2007, 12:34 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Service vehicle ,abs, and trac off lights
Thank You.
Take it to Autozone or some similar place and have them put a scanner on it. This is a free service and they will be able to tell you what diagnostic trouble codes (DTCs) are being set that are turning on the malfunction indicator lamp. Until we know what the DTCs are, we can't help much.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-24-2007, 01:43 PM
They said it is my left rear wheel bearing and my Oxygen sensor. The dealer wants to charge $640 for repairs. Is this unreasonable?
Old 01-24-2007, 01:56 PM
maxwedge maxwedge is offline
A990 racer
Yes it is possible, make sure you get a guarantee from them that this will correct you problems though.
Old 01-24-2007, 02:52 PM
Blue Bowtie's Avatar
Registered Offender
Their explanation is plausible, since the rear wheel hub/bearing likely contains the wheel rotation sensor. Lacking a signal from a wheel sensor, the ABS and traction control systems should deactivate and illuminate a warning lamp. The oxygen sensor suggestion may simply be due to their analysis of another stored trouble code indicating any number of emissions or drive cycle problems.
However, given the cost of a heated oxygen sensor (usually under $90 and ten minutes to replace) and the rear hub/bearing/sensor assembly (usually around $240) they must anticipate some difficulty in replacing the rear hub, since the remaining appriximately $270 would be labor for that procedure.
That seems maybe just a bit high, and probably enough so that it's worth asking for a parts and labor breakdown estimate before authorizing repairs. If they can explain it to your satisfaction, go for it.
Old 01-25-2007, 05:51 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Personally I shy away from having the dealer work on my cars. I use a good independent shop, where playing "beat the clock" isn't more important than fixing the problem. Sure he gets a decent buck, but the problem is always properly diagnosed and fixed the first shot. I would at least go to one to get a 2nd opinion.
Bob
