Old 01-23-2007, 06:08 PM
99camaroconvSS's Avatar
99camaroconvSS 99camaroconvSS is offline
? bout my ring & pinion
I'm replacing my Richmond 4:10 with a 3:73. My biggest thing before I buy a new one is, what is the carrier series? There are two different ones, a 2 series and 3 series. It's the stock 10 bolt 7.5 and 7.65" Camaro rear end. It's going in my 99 SS
Old 01-23-2007, 06:56 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: ? bout my ring & pinion
you're gonna hafta open it up and look if you already have a richmond 4.10 set in there, since they make them for both 2 and 3 series carriers.
Old 01-23-2007, 08:21 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Look up the RPO codes on ur driver side door....if it says GU5 or GU6 then u get a 3 series carrier.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 01-23-2007, 10:06 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Is your car stick or auto?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-24-2007, 06:19 AM
It's a 6sp with a Richmond 4:10 already installed. The only reason for the change is the pinion is missing 2 teeth and the ring missing half of one. I had it opened up once just to see what the knocking was from. I'll check tommorrow for that code. Thanks for all the help.
Old 01-24-2007, 06:43 AM
goldz28's Avatar
goldz28 goldz28 is offline
If its an aftermarket rear end the code would not reflect the aftermarket. Should tell you what the stock rear is.
Nice looking car there, welcome to the forum.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 01-24-2007, 08:45 AM
FormulaLT1's Avatar
Fight the powwa!!!
If you have a 6sp then you have a 3 series. No need to check RPO's cause all the ring gears available for your rear are 3 series.
Old 01-24-2007, 10:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a link that may be of some help.
Good Luck. MT
http://www.differentials.com/install.html
MT
Old 01-24-2007, 12:25 PM
z28 boy's Avatar
This is true
2000 Z28 A4:
Old 01-25-2007, 09:39 AM
Last question...I have been looking through the install kits and I must be looking to far into it cause Richmonds kits are only up to a 1998 10 bolt 7.5 & 7.65 rear end. I thought they were the same as the 1999 and up? I do appreciate all the help from everyone. Thank you again
99 SS Conv
LS1 6sp w/few bolt-ons
One of the only Conv w/rollcage
Getting rid of the GTR wing as soon as I get the money for a factory SS wing
Old 01-25-2007, 01:41 PM
FormulaLT1's Avatar
Fight the powwa!!!
Torsen units where used starting in 99 and if I remember right, I think something with the axle seperator bolt might be different but besides that, you are correct. They are the same and should be able to use the same install kit.
Old 01-25-2007, 02:48 PM
z28 boy's Avatar
You right about the Torsen's in the 99+......i bought my gears and install kit from jegs....should look them up.
2000 Z28 A4:
