Old 01-23-2007, 02:43 PM
formzy formzy is offline
Harsh shift into reverse!
I have this '90 Lesabre and the transmission shifts smoothly and shifts into drive just fine. The problem is a very hard or "slamming" shift into reverse. Does this sound like a shift solonoid or something? Anybody have a similar problem on the same car? Also any particular area to check other than tearing down the transmission. Thanks
Old 01-24-2007, 10:41 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Harsh shift into reverse!
Check the modulator vacuum hose for a leak, or if it has any signs of transmission fluid on the inside of the hose.
Old 01-24-2007, 11:23 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
There are quite a few TSB's regarding the issue. My wife's '89 LeSabre had the same issue. Before looking into the TSB's I did as suggested I replaced the vacuum modulator and mounts, no dice, the TSB outlines a internal problem.
