Temp Guage Stopped Working
My temperature guage suddenly stopped working this week, pegged at the cold end of the scale. A quick look didn't turn up anything obviously disconnected. I can live without it, but will the guage malfunction influence my ECM's settings and self-adjustments? If so, I should try a little harder to fix it soon.
Thanks. |
Re: Temp Guage Stopped Working
I'm not sure if it will affect your ECM but I'm guessing it probably does. Do you have a haynes repair manual for the Metro, definite need if your going to be fixing your own car, If you don't I scanned the page from the manual that will fix your temp guage problem. Check your fuses first, you might get lucky and its just a bad fuse. Its probably your Coolant Temp Sending Unit though.
1997 Geo Metro 1.0L 3cyl 1.75" exhaust from the cat back, IMCO glasspack, IMCO turbo muffler 3tech Performance 10+ Advanced Cam Gear +9 degrees ignition advance 87 Octane Mobil 1 Synthetic 10w-30 20% tinted windows |
Over the weekend, I unplugged every electrical connection and fuse under the hood and cleaned each one. It's surprising how many connections there are. I would say about 20-25% had some degree of corrosion or dirt on the contacts, again surprising. Of course, the car wouldn't start after that - but I quickly found two connections that failed to reconnect adequately. The temperature gauge is working once again, I can't comment on which connection did the trick. It may be my imagination, but the car seems to idle cold better than before - but I do have a vivid imagination. Thanks to everyone for the helpful replies, you guys are great!
