Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-23-2007, 10:57 AM
Drodman Drodman is offline
Send a message via Yahoo to Drodman
Suggestions
OK I know I can probably search for this stuff but I really am getting lazy in my old age. I need to replace some things this winter in my car and I want only the best. Here is what I need to replace and if you could tell me what is the best and where I could get it that would be great.
1. Spark Plugs and wires (Need exact name and details)
2. Timing belt (I have 101000 and pushing my luck)
3. Trany fluid (The best)
Anything else you think I should replace at 100,000 miles?
Thanks for your help.
Dan
MODS:
2001 Mitsubishi Eclipse GT Spyder,17" Konig Wheels, AEM Underdrive pully and Air Intake System, B & M Short Shifter with MOMO boot & shift knob, High Performance Drilled & Slotted Roters w/Hawk Brake Pads, Centerforce Stage 2 Clutch, Fidanza 9lb Flywheel and a Magnaflow Full Catback Exhaust System.
Old 01-23-2007, 11:50 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Suggestions
Wow you are lazy...
I would throw some NGK plugs in with some MSD wires or something like that. An OEM timing belt will work fine unless you wanna shell out a good bit of cash and get a kevlar timing belt. Then again, they might not even offer them for your car. If anybody would carry them it would be Greddy. Now for the tranny fluid I would go and run something like a mixture of shockproof and syncromesh. Only because I have no idea how durable your 3g trannys are. I know in my tranny I run straight syncromesh but like I said, it could be too thin for your tranny...
Don't be scared of the search button. It won't bite you.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-23-2007, 02:42 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Suggestions
I heard Royal Purple trans fluid is supposed to be awesome. When I get around to flushing my trans thats what I am putting in. As for the timing belt, I have heard that the kevlar ones might give your problems, and you are better off using an OEM belt (it was either discussed here on at club3g.com).
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-24-2007, 12:26 AM
Re: Suggestions
What kind of problems can be caused by using a kevlar timing belt? I've never seen anybody run into any types of problems with them before. (Not on 2g's anyways)
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-24-2007, 01:42 AM
rodbls's Avatar
Re: Suggestions
I dont know if any of this is true, but from what I remember the main point was that because the kevlar wouldnt flex as much as the OEM belt, instead of breaking, it shreds. Since the belt cant expand at all, the regular belt around the kevlar core might shred....again, not sure if any of it is true, but it sounds like a reasonable explanation. Also from what I remember, it was not a problem with kevlar belts in general, just the ones manufactured for the 3G...so this is not to say that other cars are not better off with a kevlar belt, just not ours.
Old 01-24-2007, 02:00 PM
Re: Suggestions
OK I found lots of different types of this tranny fluid. I do have a 5 speed and I was wondering if that made a difference in what to get? Thanks for your help.
Dan
MODS:
Old 01-25-2007, 12:29 AM
Re: Suggestions
Ahh ok. Well thats good to know either way. I can keep an eye on mine and take note to any cracks or changes I might see in it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-28-2007, 02:55 AM
brad02420's Avatar
brad02420 brad02420 is offline
Re: Suggestions
Dan
I use BG Syncro Shift. I noticed a huge improvement on those first couple shifts from 1st to 2nd on cold days (Surely you know what I'm talking about). You can probably find it about anywhere but heres the link to where I purchased mine. http://www.roadraceengineering.com/3gfluids.htm
North Star White 2000 Eclipse GT 5 Speed.
Mods-Greddy EvoII Exhaust System,Injen Cold Air Intake,Megan Racing Short Shifter,ES Shifter Bushings,Greddy Counter Weighted Shift Knob, Fidanza Lightweight Flywheel, Prothane Motor and Trans Mounts,Clear Corner Lights,APC Euro Tail Lights,Mio C520 GPS,Passport X50 Radar Detector,Sony Xplode HU.
