Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-23-2007, 08:21 AM
hoe3 hoe3 is offline
4WD HI Pulls to the Right
Hello All,
2001 Tahoe when shifted to 4WD HI has a fairly severe pull to the right.
Switch back to 2WD and she is straight as an arrow. Any ideas as to what and why?
thanks!
Old 02-24-2007, 12:38 AM
aznjeep's Avatar
aznjeep aznjeep is offline
Re: 4WD HI Pulls to the Right
Depending on the type of 4x system you have, this may be common. Did you buy the Tahoe new? If so, then you most likely don't have a front locker. If you bought it used, you may want to check to see if the previous owner added an automatic front locker of sorts. On my Jeep, once I added a front locker, I have the same problem.
If no locker, check to make sure your tire sizes/tread wear is even on all 4 tires. When in 4Hi or Lo, the transfer case splits power 50/50 to front and rear. If the tires are not the same size, then either the front or rear axle will want to turn slower than the other...
Old 03-26-2007, 10:07 PM
silveradoseaver silveradoseaver is offline
you might check the condition of your cv axles. If one is broken it could possible cause this reaction. Maybe?
