Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-23-2007, 07:37 AM
vintageagain vintageagain is offline
gauges
my oil and temperature gauge don't seem to work. Does anyone know the operating voltage of the gauges. In other words, if i apply 12 Volts where the output of the sensor would be then i would expect a reading of High or Low oil pressure/water temp? I'm looking to start with trouble shooting the guage before i move onto the sensors. This is for a 95 Wrangler with about 115k on it. Thanks in advanced.
Old 01-24-2007, 03:43 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: gauges
I'm not sure on the voltages, but I had a similar problem with my 93 YJ when I got it. my problem turned out to be a bad spot in the printed circit that is on the back side of the guage cluster. the bad spot on mine was in the 12volt power to the guages, I just made a jumper to bypass the bad spot, and the guages have worked fine ever since.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
