Not Honda related, but worth a try...
Hey all.
A friend of mine owns an '88 Chrysler LeBaron Turbo, and he's had to replace the pickup coil (inside the distributor) several times. It went out again yesterday, and he's tired of replacing it... Have any of you had this problem at all, and if so, what's the fix? The problem with the pickup coil is obviously not the real problem, it's only a symptom of something else... Would he be better off replacing the entire distributor? Would an external ignition system (such as an MSD electronic ignition) help at all?
yeha i would replace the dizzy,,,but not with an msd one at first. just get an oem one and see if it is even a dizzy problem.
1997 Toyota 4Runner Limited Built ZC in 90 Civic std model.... ![]() as marked001 says Don't click here |
Yeh thats the same shit i'm goin through now. I replaced the coil and its already burnt. I replace the cap but didn't replace the rotor yet.
Tell him to ditch the car and take his turbo..
![]() Sorry..that wasn't much help was it. I had an 85 Mazda that had similar problems..it turned out to be the ignitor burning up the coil..A distributor from a junkyard for about $125 fixed the coil problem.
-Shawn '91 Civic DX sedan DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Replace the entire distributor assembly...Everyone seems to be having distributr problems including myself. The bearings on my 1st b16a dizzy went but they are known to do that.
91 civic 4dr b16a 14.8@94 |
yeah its probly a waste of time replacing every little bit ... just replace the hole dizzy it will save a hoel lot of time ....
1989 Toyota Supra 3.0i Turbo 150mph I think I'm nuts Custom S/S Exhaust 5" Tailpipe K&N Induction kit Bailys Piston Dump Valve (WOOSH) Wategate Shimmed by 5mm ummm boost ![]() |
Thanks guys. I'll tell him. :sun:
Is the distributor modified in any way?
Is the coil arching? Does the distrib. have some sort of igniter like Honda, if so try replacing that with a new coil, cap, rotor. No need to replace the entire assembly if not needed. |
