Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-23-2007, 02:50 AM
DSMNerd6889 DSMNerd6889 is offline
Possible overheating?
Hey guys, I was driving home last night from work (very cold). And my car was acting really funny. First off, it wouldn't heat up to turn the heater on. The gauge never read very hot, but on my way home my car died at a stoplight, it took a little bit, but I was able to get it started again. Then it died again as I was waiting for my garage door to open. I wasn't able to get it started again. When I looked under my hood, there was steam and gargling coming from the radiator cap. I really am not sure what's going on here, my initial thought is thermostat. Any other thoughts? Thanks in advance!
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 01-23-2007, 08:57 AM
Re: Possible overheating?
After taking another look under the hood this morning, I may have spotted my problem. On my thermostat housing there is a small threaded plastic piece that two vacuum hoses go into. That piece appears to be broken off. When I went thru my Chilton and Haynes manual the only reference I saw was calling it a thermo valve. Would this cause my thermostat not to open? Also, does anyone know where I could get one of these? Thanks in advance.
1990 GSX
Old 01-23-2007, 10:21 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The thermostat is only reactive to heat and nothing else, so no, that would have anything to do with it. Besides it stalling, did it run fine (idle, crusing, etc)? These cars have a tendency to warm up quite slowly (or mine did) on a very cold night (any car does if it's extremely cold), so that may be part of the problem too. If you find it never gets to normal operating temps in the cold weather, just ziptie a piece of cardboard in front of the radiator (behind the bumper), and that should help. Just remember to take it out once it starts to get warm again.
95 Talon TSI AWD
97 Eclipse GST
Old 01-23-2007, 10:40 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
^that valve... I have it disconnected on my car... all it does is run vacuum through the valve to allow the coolant to flow into the throttle body to heat the car when it's warm...
^try Garret's trick to help the car warm up faster, and make sure you have enough coolant in the radiator (if air gets in there, the water pump won't be able to pump water through the block, but then you'd know it was over heating...the thermostat would get really high, and you'd be boiling coolant out the overflow)...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-23-2007, 11:49 AM
Well, what I'm wondering now is if I need that valve hooked up since I live in a cold climate, last night when all this happened it was 15 degrees. I read somewhere that when the coolant doesn't run thru the throttle body that it'll idle high (which it was doing) do you think these problems could be due to the fact that my tb wasn't getting any heat? Thanks again.
1990 GSX
Old 01-23-2007, 12:04 PM
Yes, it could be. Fix that connector and see if it helps. And if it's only 15, then your car should operate fine. I'm from ND and when you said very cold, I was thinking along the lines of like -20, but no need to use the cardboard if it's only 15 outside.
95 Talon TSI AWD
97 Eclipse GST
Old 01-26-2007, 02:39 AM
Okay, so I think my problem was that my coolant froze. I found a busted coolant hose between the thermostat and the turbo. After I replaced that I found a lot of coolant leaking from the drivers side of the motor, I'm thinking it's the water pump but was wanting to know if we have freeze plugs or anything like that that I may look into. Thanks.
1990 GSX
Old 01-26-2007, 07:06 AM
Mikelb's Avatar
what mix antifreeze/water u running?
50/50?
Old 01-26-2007, 10:43 AM
Your coolant froze!?! That's an extremely bad thing. Worst case scenario, the block is cracked. Lucky case scenario, you broke a coolant hose. Run a 50/50 mix of green antifreeze and water. If I was you, park your car inside for a few days to let the coolant melt, drain the cooling system, and then re-fill it back up and make sure that ALL the hoses are in good condition.
There are freeze plugs, but if you actually froze the block, you most likely fucked the water pump too.
95 Talon TSI AWD
97 Eclipse GST
Old 01-26-2007, 10:02 PM
No, it's not like all the coolant froze, but like bits of ice. It's all fluid now, but I blew out a hose and now there's a leak coming from around the water pump I think. Does anyone know where the freeze plugs are on our cars? Thanks again.
1990 GSX
Old 01-26-2007, 10:13 PM
There's 3 or 4 on the front and 4 on the back. You do know what frost plugs are right?
95 Talon TSI AWD
97 Eclipse GST
