Old 01-22-2007, 11:09 PM
stnapycnaf stnapycnaf is offline
Clutch Pedal Vibration
I've noticed that whenever I'm accelerating my clutch pedal vibrates
my passenger side cv axle is busted ... i'm just curious whether that would be what's causing the vibration ...
either way I'm getting a new clutch setup and axle ... I just wanna know whats up
thanks guys and gals
91 CRX HF
D16A6 Swap
Old 01-23-2007, 12:01 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Clutch Pedal Vibration
Could be the throwout bearing, or the clutch..but its most likely the vibration from your axle
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-23-2007, 03:20 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
its probably the pressure plate. My g/f's mustang has been doing it for 2 yrs now, damn clutch kit is expensive for it. Could also be the axle, but if you plan on replacing the clutch and axle, you should knock out that vibration.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-23-2007, 06:19 PM
cool ... thanks guys
... also
about how risky is it that i'm rollin around on this axle?
91 CRX HF
D16A6 Swap
Old 01-23-2007, 06:35 PM
FrodoGT's Avatar
Very, even if it doesnt leave you stranded ( which it will eventually) It could get you in trouble. I had my axle lock up on the highway when I was really moving, and I could have died if I had hit something, almost sent me off the road...both sides of the road.
Current project:
Rio Red 91 hatch.
Old 01-23-2007, 09:28 PM
DuiSonOfDarp's Avatar
DuiSonOfDarp DuiSonOfDarp is offline
Send a message via AIM to DuiSonOfDarp Send a message via MSN to DuiSonOfDarp Send a message via Yahoo to DuiSonOfDarp
I got a busted axle to but it seems okay to commute with, as long as I don't play around of course. I've been riding around like this now for about a month. A week after i bought the car I broke both axles and only replaced the left side axle lol, it was the only one they had in stock.
Old 01-24-2007, 12:55 AM
FrodoGT's Avatar
Yeah, I drove on my left one (the one I didnt replace after the right one went) for like 2-3 months..till I drove 60mi out of town, and felt it start locking up, had to pull over, manage to make it there and it started locking again. Both times it went away. then just as I was pulling into a parking garage it let loose, the splines were flattened at the end of the shaft and there were metal shavings EVERYWHERE.
Current project:
Rio Red 91 hatch.
Old 01-24-2007, 01:16 AM
well i know what my next purchase is going to be
91 CRX HF
D16A6 Swap
Old 01-24-2007, 10:59 PM
viper-blue's Avatar
viper-blue viper-blue is offline
what set up are you running to get to that speed with such low rpms?
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 01-25-2007, 09:16 AM
My setup is completely stock ... and I have an HF ... so redline is 5grand ...
as far as axle's ... would a junkyard axle be fine or should I just go get a new one?
NOTE: As far as spline count ... do rex axles differ at all from HF to DX to Si?
91 CRX HF
D16A6 Swap
Old 01-25-2007, 09:52 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Yes there is a difference at the hubs if I remember correctly. I think you can either have to use HF specific axles or swap out the hubs for dx/si ones to run dx/si axles. Do a search in this forum. It's been covered a bunch.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-25-2007, 10:53 AM
Tony's Avatar
TLD Member #1
Don't waste your time with junkyard axles. Its a waste of time and money. Sometimes you get lucky, but most are junk. Plus some places will charge you the same for a used one as you would pay for a new one.
Tony
Old 01-25-2007, 11:19 AM
thanks ... good to know
91 CRX HF
D16A6 Swap
Old 01-25-2007, 07:09 PM
viper-blue's Avatar
I've found out from experience that the hf,dx,si hubs are are all the same...the difference is the hf tranny has a different spline count..so the inner joint won't match up..the outer joint has the same spline could as a dx,si though
